Brake hose alternatives
  • ggenovez
  • ggenovez's Avatar Topic Author
03 Jul 2013 17:30
#594911
Hi all,
I have a 81 kz1100 and the original brake like are starting to show their age.
I noticed replacement brake lines are a little pricy
Are there any alternatives? what about stainless braided? anybody know a good source.
Also, what would be the correct length, how do you measure, and is 10mm banjo the correct size?
Thanks again.
George
KZ-1100 A1
Re: Brake hose alternatives
03 Jul 2013 18:00
#594919
You may want to contact the folks in the links below and ask about measuring for new lines. Also, be sure to get plastic coated lines or the stainless steel braiding will saw through anything it comes in contact with. One other tip, take careful notice of the angle of the banjo fittings on your original lines and be sure to order the same angles. I've seen installations that look really bad because the banjo fittings are straight where they should be angled. Ed
www.cyclebrakes.com/html/galfer_brake_lines.html
apexbrakes.com/custom.asp
The following user(s) said Thank You: bluezbike
  • steell
  • steell's Avatar
03 Jul 2013 18:16
#594926
You can also take your lines off and take them to a hydraulic hose shop and they can probably make them. The one I checked with locally said he could do it, but he was too expensive for me.
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
04 Jul 2013 16:55 - 04 Jul 2013 16:56
#595066
These guys made some SS hoses for my H1 while I waited. I had to go custom due to lower bars. They can also make the standard rubber hoses. Located in GA pretty close to the Airport. It's a great old school auto parts store.
E.L. Johnston
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
Last edit: 04 Jul 2013 16:56 by ThatGPzGuy.
  • KZJOE900
  • KZJOE900's Avatar
  • Administrator
  • Administrator
    Super Users
05 Jul 2013 09:59 - 05 Jul 2013 10:00
#595126
Z1Enterprises carry them as well for what seems to be a good price.
Z1E Stainless Steel brake lines
They come in black or clear coated SS lines.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Last edit: 05 Jul 2013 10:00 by KZJOE900.
