brake pad/shoe replacement advice for 81 650csr
  • jbalet666
  • jbalet666's Avatar Topic Author
02 Jul 2013 23:16
#594801
so im replcing the brakes on the 81 650 csr
too many choices ie. carbon,sintered,groved etc
any help?
81 650csr
AoA
old soul young blood
Re: brake pad/shoe replacement advice for 81 650csr
02 Jul 2013 23:19
#594802
I would go with stock Kawasaki pads (they are still available). Otherwise you may find the brakes squeal a bunch. Ed
  • jbalet666
02 Jul 2013 23:53
#594809
650ed wrote: I would go with stock Kawasaki pads (they are still available). Otherwise you may find the brakes squeal a bunch. Ed
so something like this is a bad idea?
81 650csr
AoA
03 Jul 2013 00:43
#594814
Sorry, I'm not familiar with brake shoes; I was thinking of disk brake pads. Maybe someone with brake shoe experience will chime in. Ed
  • RonKZ650
  • RonKZ650's Avatar
03 Jul 2013 01:00
#594815
Brake shoes are kind of like shoes you wear on your feet, they all work for the most part, some better than others. These probably work just fine. Shoes are easy, it's the disc pads that are a real pain and you mostly need to stay stock Kawasaki unless you want to sound loud as a fire engine every time you stop. :P
  • martin_csr
  • martin_csr's Avatar
03 Jul 2013 11:42 - 02 Dec 2013 15:36
#594866
I installed Vesrah brake shoes & they work just fine. Others had mentioned brake squeal, so I sanded the leading edges of them & I also sanded the drum very carefully & methodically to remove the old glazing. Use brake grease in the proper places, such as the pivot points. Don't get any grease on the braking surfaces. I use the Permatex Ultra Disk Brake grease in the little packets.
Last edit: 02 Dec 2013 15:36 by martin_csr.
  • jbalet666
03 Jul 2013 18:49
#594935
hahahah ok thanks alot
i saw the price for both pads and shoes from kawasaki and i almost had a heart attack hahaha but if i just go with stock kawi pads and aftermarket shoes theres nothing wrong with that
81 650csr
AoA
