Mono to dual shock conversion (Who's done it?)
  • K.D. HART
  • K.D. HART's Avatar Topic Author
01 Jul 2013 11:07
#594585
I know I have seen members converting mono shock swingarms to dual shock.
I have a 1995 GSXR 750 suspension, but not sure I want to go mono.
I've been trying different search terms for the last hour to find pics and info on dual shock swingarm mounts, but I'm not having any luck.
Could someone please point me to these threads or pics?
Thanks
  • K.D. HART
  • steell
  • steell's Avatar
Re: Mono to dual shock conversion (Who's done it?)
01 Jul 2013 16:24
#594615
Done it with 83-85 ZX750 swing arms, but never with a GSXR.
Z1 Enterprises has the brackets.
  • K.D. HART
01 Jul 2013 20:24
#594628
steell wrote: Done it with 83-85 ZX750 swing arms, but never with a GSXR.
I seen Z1 has them for sale. Do you have any pics of what you done?
  • steell
  • steell's Avatar
01 Jul 2013 21:30
#594638
Don't think I have any pics, but I cut off the bottom dogbone mounts and welded them on top as shock mounts. Worked out well for me :)
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
02 Jul 2013 16:19 - 02 Jul 2013 16:19
#594734
buy some mounts,set em as close to factory position as you can and weld em on !
it ain't rocket surgery :P :woohoo: !
Last edit: 02 Jul 2013 16:19 by 531blackbanshee.
  • K.D. HART
02 Jul 2013 18:56
#594761
531blackbanshee wrote: buy some mounts,set em as close to factory position as you can and weld em on !
I wanted to see what it would look like and thought someone might have already done it with a GSXR swingarm.
If I could do photoshop I'd already taken pics of testarossa's blue 78 KZ1000 with the 1995 GSXR 750 suspension
[IMG
and added a different styles of sport fairings, chin scoop and shocks, to give me a better image of what the end product will look like.
I really like the look of my old 78 LTD
[IMG
P.S. I was just getting ready to P.M. you back anyway. I'll get you the info you need as soon as I get a chance to go look.
  • 531blackbanshee
  • Vendor
  • Vendor
03 Jul 2013 09:48
#594841
both are awesome looking bikes.
the overbraced arms like testa's presents some interesting challenges when trying to dual shock one.
a busa arm with the upper brace removed and an underbrace added would be ideal to dual shock a kz with.
imho,
  • K.D. HART
03 Jul 2013 11:15 - 03 Jul 2013 11:18
#594857
531blackbanshee wrote: both are awesome looking bikes.
imho,
Leon,
I've thought about the GSXR overbrace problem and that's part of the reason I wanted to see what others might have done, before I told my idea and was thrown under the wheels of the bus.
I took a good look at the GSXR swingarm and see no reason I can't flip it 180 degrees.
I'll have to switch the brake caliper mount and chain wear guard (black nylon piece) to the other side.
The overbrace, would now be an underbrace.
Try to imagine testa's bike.
[IMG
With the swingarm like this.
[IMG
I even looked at the ground clearance and it looks like it should work. It doesn't look like the bracing would hang any lower than the underbrace I put on my 1978 LTD.
[IMG
Last edit: 03 Jul 2013 11:18 by K.D. HART.
  • StreetfighterKz
  • StreetfighterKz's Avatar
  • Away
03 Jul 2013 11:25
#594859
I have a '94/95 Gsxr750 arm on my '89 Gsxr750. If I recall correctly the arm is not symmetrical. I think the left side bows out more for chain clearance than the right side. Plus the caliper bracket is "armless" so you would have to weld a stay of some sort onto the arm if you flipped it.
There was a non-braced Gsxr swingarm in the classifieds at one time that could be set up with the same wheel fairly easily and the bracing wouldn't be a concern.
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • K.D. HART
03 Jul 2013 11:41
#594865
StreetfighterKz wrote: I have a '94/95 Gsxr750 arm on my '89 Gsxr750. If I recall correctly the arm is not symmetrical. I think the left side bows out more for chain clearance than the right side. Plus the caliper bracket is "armless" so you would have to weld a stay of some sort onto the arm if you flipped it.
Later, Doug
Doug,
I'll look at it again and measure it, but it looked pretty symmetrical to me. I didn't notice any difference when I put the chain rub pad (black nylon pad) on the other side, when I flipped it 180.
I already mentioned the caliper bracket. It's an easy fix. Just cut off and weld on the other side.
  • K.D. HART
