need help with 81 kz 550
  • Dirk2013
  • Dirk2013's Avatar Topic Author
27 Jun 2013 00:20
#594074
Hi,
My 81 KZ 550 has problem ,starter will turn over with key off and engine run switch off why? it also has no spark ?
Dirk Gadberry Sacto Cal
Re: need help with 81 kz 550
27 Jun 2013 04:57 - 27 Jun 2013 05:01
#594091
Dirk2013 wrote: ...81 KZ 550 has problem ,starter will turn over with key off and engine run switch off why? it also has no spark ?
Hello, Dirk, and WELCOME to KZr! :cheer:
Perhaps there's a malfunction within the ignition switch itself, such as a short, corrosion, worn out, etc.
:unsure: I don't know whether or to what extent the switch might possibly be disassembled for inspection and/or repair. Or if it might help to spray it internally with an electrical cleaner such as Deoxit.
If a replacement switch is needed, would check for availability at Z1 Enterprises.
For an example, click > www.z1enterprises.com/ItemDetails.aspx?i...lock&item=EM40-80610
As for no spark, would begin diagnosis by assuring that both ignition coils are receiving battery voltage.
Also, if needed, there are wiring diagrams in KZr's FILEBASE.
For one of the diagrams, click here > www.kzrider.com/filebase/doc_download/301-z550a2
Attachment filebasekzr.jpg not found
Could also check out the info and service manuals provided by KZr member, loudhvx:
General-- home.comcast.net/~loudgpz/GPZweb/index.html#home
Service manuals -- home.comcast.net/~loudgpz/GPZweb/Mnls/Mnls.html
Good Fortune! :)
Last edit: 27 Jun 2013 05:01 by Patton.
The following user(s) said Thank You: Dirk2013
  • Dirk2013
28 Jun 2013 00:08
#594177
SO check this out. Un bolted cid box tonight, basically it is no longer grounded to frame but has all wires connected. Now started will not turn over with key off :) But still no spark :( I'm thinging the cid box is suspect?
Dirk
  • lightitup
  • lightitup's Avatar
28 Jun 2013 01:36
#594199
or u have a something grounding to the frame that shouldnt be and the cdi box is being affected by it
81 kz 550 ltd
  • Dirk2013
28 Jun 2013 21:34
#594286
Ya I think that may be possible. I changed cdi today and it does the same thing :( any idea were ground problem could be ?
29 Jun 2013 00:07
#594300
If possibly referring to the IC Igniter wiring, it likely has a ground wire (usually black/yellow) that must be properly grounded.
Good Fortune! :)
  • Dirk2013
29 Jun 2013 18:49
#594361
So I put back in old IC igniter, checked and cleaned every connector and ground. Now it works, No sure were problem was? Most of the connector plugs had corrosion in them, maybe just a bad connection?
Thx for your help Dirk
  • lightitup
30 Jun 2013 21:50
#594523
some times u just have to clean
81 kz 550 ltd
