Clutch failed while riding. Is it the cable?
- Hollywoodmx
24 Jun 2013 21:39
(B2 GPZ1100)
So I'm riding along 4th gear 70k/hr, went to grab the clutch leaver and it was more limp then a dude seeing Jessica Parker nude. It was like the cable broke.
Limped her home through some savvy techniques and some luck too. I thought the magnet part fell out of the case cover but it didn't. Upon inspection the magnet part with the 3 balls looked like the balls were causing some slight groves (wear) in the piece. I don't think this is related though.
Any ways I traced out the cable for damage and cant seem to find anything wrong other than the following;
The clutch adjustment locking bolt was loose. I readjusted as per the manual. Fixed that but clutch doesn't feel right still.
The cable seems longer, even with adjusting both the leaver adjuster and the mid way adjuster to the max I safely can, I cant get the play out back to the spec of the manual. Instead of 1-2mm of play it's more like 5+mm and clutch doesn't feel right.
Is my cable stretched?
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Re: Clutch failed while riding. Is it the cable?
24 Jun 2013 22:13Just for grins, loosen lock-nut, and adjust the screw to light seat by turning it opposite to what the manual says, then reverse 1/2 turn, then tighten the lock-nut.Hollywoodmx wrote: ...The clutch adjustment locking bolt was loose. I readjusted as per the manual. Fixed that but clutch doesn't feel right still....
25 Jun 2013 10:24
I would remove & inspect the cable. At the least, you should disconnect it from the lever to see if it's broken or something.
- zed1015
25 Jun 2013 15:20
Pull the clutch cover and see if the center nut has come loose allowing the basket to slide before disengaging.
As a quick check you may be able to see the basket moving out by looking down the oil filler.
It will only need the nut to loosen by a small amount to give your symptoms.
Other possible causes = broken clutch springs, shattered pushrod ballbearing etc.
- NZGlenn
25 Jun 2013 23:19
Try adjusting the cable at the threaded part half way down the cable. This will be clip to the frame in the elements and beside the left hand header. This is probably corroded and won't adjust. Buy a new cable and then adjust as per other replies and the manual.
1984 GPz1100A2
- Hollywoodmx
30 Jul 2013 01:36 - 30 Jul 2013 01:43
I bought a new bike so I left the gpz in a lonely state as the new bike monopolized all my time. This weekend I took the cable apart at all ends and removed the clutch. put it all back togther and its now fixed. I ran it tonught and its fine.
There is some damage, what do you guys think? Are those sliding grooves normal or are they supposed to round to match the balls?Is this part hard to find?
Attachment 20130728_145403_HDR.jpg not found
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Last edit: 30 Jul 2013 01:43 by Hollywoodmx.
30 Jul 2013 09:42
No eBay APP ID and/or Cert ID defined in Kunena configurationIt looks like that's scored quite a bit although the oblong dimples appear to be normal (see NOS pic below). If it was mine I would replace it. The good news is that Kawasaki.com still lists that as an "Active" part (see diagram below) and that Partzilla lists it at only $32. Plus, there's a NOS one on eBay for $30 delivered (see bottom image). Ed
find.partzilla.com/?r=t&q=13102-1012&x=6&y=10
Attachment 00001_2013-07-30.jpg not found
Attachment 00000_2013-07-30.jpg not found
- Hollywoodmx
30 Jul 2013 19:15
Thanks man, I will pick one up.
In the end I'm not sure what caused the original issue. I'm leaning mostly toward the clutch pack got stuck somehow.
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
30 Jul 2013 19:29
Be sure to keep it greased. Ed
- Hollywoodmx
30 Jul 2013 21:59650ed wrote: Be sure to keep it greased. Ed
It funny you say that, cause I normally slightly overfill the oil and dont listen to the manual. The manual says oil at half way mark after the bike is warm and on center. But that scares the crap out of me. I followed the manual this las oil change and then the clutch acts up...so may be its not worth following the manual...
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
30 Jul 2013 22:19
Oh, sorry I didn't word that well. I meant be sure to keep the new clutch release mechanism greased so it doesn't get scored. Ed
