Helmet Lock
- 78 Kz650 Rider
Re: Helmet Lock
23 Jun 2013 21:25
If you are referring to the seat lock it should use the same key as the ignition and fork lock. If someone changed yours and it uses a different key take a close look at the lock next to the keyhole. There should be a 3 digit number stamped into the metal. That is the key number for the lock. If the number is there and you need a key someone here may be able to help you get one. Otherwise removing the lock is going to be tough because the bolt that holds it on is under the seat (see arrow in pic). Ed
Attachment 00000_2013-06-23-3.jpg not found
