Gauge cluster meter-bracket (KZ1100-A)
  • daveo
  • daveo's Avatar Topic Author
  • Premium Member
  • Premium Member
10 Jun 2013 12:23
#591582
Has anyone experienced breakage of the gauge (meter) bracket (at the bend), and what solutions the great-minds have come up with, short of replacement?
When available from Kawasaki, the 25008-1034 meter-bracket was pricey.
1982 KZ1100-A2/1170 sleeper 😀
  • martin_csr
  • martin_csr's Avatar
Re: Gauge cluster meter-bracket (KZ1100-A)
10 Jun 2013 14:53 - 19 Jun 2013 10:31
#591626
No eBay APP ID and/or Cert ID defined in Kunena configurationHave it rewelded? And maybe add a little extra material here n there for strength? I'm assuming it's steel.
My neighbor fixed a Honda Element fuel door hinge fairly easily... seems like a meter bracket could be done the same?
Not sure if this is correct for your bike.
Using Kawasaki.com: ..... (partzilla info seems to be incorrect)
25008-1034 BRACKET-METER
Model (5):
KZ1100-A1 (Shaft) (1981)
KZ1100-A2 (Shaft) (1982)
KZ1000-J1 (1981)
KZ1000-J2 (1982)
KZ1000-R1 (Eddie Lawson Replica) (1982)
The 82 Spectre 1100-D1 bracket looks identical to me.
25008-1035 BRACKET-METER
Model (3):
KZ1000-K1 (LTD) (1981)
KZ1000-K2 (LTD) (1982)
KZ1100-D1 (Spectre) (1982)
Last edit: 19 Jun 2013 10:31 by martin_csr.
  • daveo
  • Premium Member
  • Premium Member
10 Jun 2013 15:38
#591632
Yep, that is the one...made of aluminum, the problem.
  • Motor Head
  • Motor Head's Avatar
10 Jun 2013 22:00
#591673
Yep broke the one on mine, actually an LTD, but has same gauges. Had the thing welded back together, can't really notice it unless you go searching for the edge of the bracket. Can't see it breaking again anytime soon. It broke after some bad washboard gravel.
  • bgcarl01
  • bgcarl01's Avatar
17 Jun 2013 12:59
#592704
My 1000 LTD bracket fell off too. Going down the road. Looks like someone had welded it before. Searched and searched online, then just gave up and made a separate bracket to put stock broken bracket onto. The gauges sit a hair higher and hair forward from where they were, but no one has noticed that I ride with.
1981 KZ1000 LTD with a 1980 1000 motor, 1982 KZ750 Spectre
  • daveo
  • Premium Member
  • Premium Member
18 Jun 2013 21:25
#592955
bgcarl01
I did the same...I have a NOS bracket sitting in a box, but am reluctant to put it on the bike since they are impossible to find new, and ridiculous expensive when available from a Kaw. dealer.
  • KYKZ1100
  • KYKZ1100's Avatar
06 Jul 2013 13:55 - 06 Jul 2013 14:45
#595285
Hi,
My bracket was vibrating severely a couple of years ago and finally broke. I cut the broken bracket at the bend and bolted it to a bracket I made of 3/16" aluminum. It's solid now.
[IMG
[IMG
1981 KZ1100A1 Shaft
2007 BMW R1200R
Last edit: 06 Jul 2013 14:45 by KYKZ1100. Reason: Delete incorrect information.
