Police Bike rear drum brakes
- ed spangler
- Tennessee Z
01 Jun 2013 18:55
OK, Finally got all the shift linkage stuff solved,
:-)good Friend in Arizona
went to a Bike Boneyard there , found me rest of parts I need for the Shift Linkage. So today layed out all the Brake stuff, thought I had that covered.....NOPE!..... I have the Brake arm one piece of slotted linkage which takes the thing back to where a Standard bike would have the standard brake pedal mounted. Since I have rear drum brakes, now I have to figure out what from that point is supposed to connect and operate the rear drum brakes by levers , linkage etc.. Anyone have an exploded parts views of Rear Drum brake operated police Bike????? At least if I could see what was originally used, if I cant find it....Hell, Ill make it!! Appreciate any help!!
Ed Spangler
ed.spangler68@gmail.com
Ed Spangler
Have 1975 Kawasaki Z1-B & 2003 Harley Davidson Heritage Softail Classic
Had Hondas, Harleys and many ,many Z Series Kaws both Std. & LTD's
Re: Police Bike rear drum brakes
01 Jun 2013 22:00
What Police bike is it? I didn't think any of the them had a drum brake, in the US anyway.
Not sure what help this will be, but perhaps check into the Rr brake on the Z1 or 76 KZ900?
Rr-brake diagram, Footrests/Brake-pedal diagram, & Swing-arm/Shock-absorber diagram.
The Partzilla site is easy to use, so you could zip around there pretty quick to see if anything looks familiar.
Also, internet photos & ebbaayy pics might help?
01 Jun 2013 23:29martin_csr wrote: What Police bike is it? I didn't think any of the them had a drum brake, in the US anyway....
+1 Kawasaki.com shows rear disk brakes on all police models starting in 1978. Maybe someone did a switcheroo? Ed
- ed spangler
- Tennessee Z
02 Jun 2013 07:54martin_csr wrote: What Police bike is it? I didn't think any of the them had a drum brake, in the US anyway.
Also, internet photos & ebayy pics might help?
Actually there were '75 Model Police bikes made!!!,( California ) Now if necessary I can provide proof.( Did my homework, and bike I bought these parts from was actually alleged to be a '74 prototype!!, ).
Mine is a standard '75 Z, I bought all the Mounting Bars,Floorboards,Heel Toe shifter and Police style brake pedal along with some linkage etc. Have everything sorted out now for shifter side thanks to my friend Dave in AZ. :woohoo: What I have for the brake side is of course mounting bar, and Brake pedal and one piece of slotted linkage. It would seem its time to break out all the modding stuff and just fabricate what I need to make brake side work...( Not going to alter stock frame in any way, want to be able to replace factory stock parts if and when I choose) Regards Ed
- ed spangler
- Tennessee Z
02 Jun 2013 08:04ed spangler wrote:martin_csr wrote: What Police bike is it? I didn't think any of the them had a drum brake, in the US anyway.
02 Jun 2013 10:13
Since it's a police bike based on the '75 Z1B it might use the same brake control parts as the standard Z1B. If so, these diagrams might help. Ed
Attachment 00000_2013-06-02.jpg not found
Attachment 00000a.jpg not found
- ed spangler
- Tennessee Z
02 Jun 2013 18:36 - 02 Jun 2013 18:36
THANKS 650ed!!!!!!
Last edit: 02 Jun 2013 18:36 by ed spangler. Reason: xyz
- P21
02 Jun 2013 18:56
you the man 650ed we be lost without your wealth of info buddy
great job! and just for that you deserve a reward enjoy man
Attachment Raquel-Welch-raquel-welch-1052517_1024_768.jpg not found
Kawasaki KZ 1000 Police (2002) P21
02 Jun 2013 21:20
That's what I call a reward!! Ed
- trianglelaguna
02 Jun 2013 21:38
look at the 73-76 brake arm...then look for the brake rod and two nuts...spring...it is not much...lemme look around online
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- kzz1king
02 Jun 2013 23:24
I think what Ed is talking about is what amounts to forward controls. From his description there is a lever where the standard pedal would be. Sounds like you just need the rear part Ed? Like Tri said, it is not much. Basically a rod that is threaded on both ends like your 75. A picture of what you have would be helpful.
Wayne
Wayne
Home built KZ1000 turbo setup
- ed spangler
- Tennessee Z
03 Jun 2013 07:22 - 03 Jun 2013 07:35kzz1king wrote: I think what Ed is talking about is what amounts to forward controls. From his description there is a lever where the standard pedal would be. Sounds like you just need the rear part Ed? Like Tri said, it is not much. Basically a rod that is threaded on both ends like your 75. A picture of what you have would be helpful.
Wayne
Thanks Everyone!!
Attached photos show what parts I have.
MANY THANKS TO DAVE in Arizona!! :woohoo: :woohoo:
Regards All!!
Again,Thanks!!
ED
Last edit: 03 Jun 2013 07:35 by ed spangler. Reason: xyz
