Flat tire
  • mopguy
  • mopguy's Avatar Topic Author
Flat tire
29 May 2013 21:04
#589810
Got a screw in my front tire,how? God only knows,pulled it out hoping it did not go through, and air started leaking out. Question is can this tire be repaired like a car tire or is it toast, it has very little mileage and is like new.
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
Re: Flat tire
29 May 2013 21:17
#589811
The tire can be patched if its a small hole but i think your bike should have a tubed front tire. I would check to make sure. you can usally tell by looking at the valve stem. If so the tube can be patched. If it was me id just by a new tube unless you know your tube is realitivly new.
1977 KZ 1000 work in progress
Re: Flat tire
29 May 2013 21:24
#589812
If the tire is nearly new and the hole is very small it may be worth saving, but there will be an element of risk. If I was going to re-use the tire I would definitely replace the tube - I would not patch it - tubes are cheaper than flesh and blood. Then I would put an inner tube patch on the inside of the tire. I wouldn't plug it because I believe the plug will rub on the tube and weaken it.
If the tire has less than 75% tread left, I would just replace it and the tube at the same time. Ed
  • mopguy
Re: Flat tire
29 May 2013 21:25
#589813
I am not sure if the tire has a tube, its a Pirelli tire that is on a mag wheel in a 1980 KZ750 LTD. The hole is not that big.
  • JR
  • JR's Avatar
Re: Flat tire
29 May 2013 21:26
#589815
If its a 750 like mine then it's tubeless and while a tire plug would get you home I wouldn't trust one for long. At least in my car I have 3 other wheels if a tire plug plug fails.
Patch and plug might be ok but that one I'd leave with my local shop. Ask shop.
If it has an inner tube then I'd patch it and ride. This was what we did in the 70s
  • mopguy
Re: Flat tire
29 May 2013 21:29
#589817
Thanks for the info guys.
  • RonKZ650
  • RonKZ650's Avatar
Re: Flat tire
29 May 2013 23:04 - 29 May 2013 23:13
#589846
1980 LTD would still be a tube type tire, so no worry, just replace the tube and you are good to go. No need to ever worry about the tire if you have a flat on a tube type wheel, just replace the tube.
Last edit: 29 May 2013 23:13 by RonKZ650.
  • mopguy
Re: Flat tire
01 Jun 2013 18:51
#590318
Took tire to bike shop and apparently it is a tubeless, so they fixed it with a plug and seems to be okay now.
  • trianglelaguna
  • trianglelaguna's Avatar
Re: Flat tire
01 Jun 2013 23:08
#590364
get a new tire,when money allows and forget about it....tube.tubless.....who cares....ride it and be safe forever but wonder all the time...mental drag imo
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • racer54
  • racer54's Avatar
Re: Flat tire
02 Jun 2013 02:14
#590389
Not being an expert on this...could you use a tube in a tubeless tire and use a patch on the tire like mentioned earlier and still use the tire...
  • bountyhunter
  • bountyhunter's Avatar
Re: Flat tire
02 Jun 2013 04:14
#590393
You could plug the tire and install a tube.
  • bountyhunter
Re: Flat tire
02 Jun 2013 04:15
#590394
mopguy wrote: Took tire to bike shop and apparently it is a tubeless, so they fixed it with a plug and seems to be okay now.
That is really dicey on a front tire.
