WIND SCOOPS!!!!!!!!
- Powerstroke_fan
WIND SCOOPS!!!!!!!!
29 May 2013 20:56
Dont know if thats what there called. but lets see them!!!! I want some ideas on whats avaiable for my 1000. I want to scoop all the air onto the motor as possible. I will be running a small oil cooler. I will be trying a few diffent ideas i got in my head. but lets see what everyone else has.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- steell
Re: WIND SCOOPS!!!!!!!!
29 May 2013 22:24 - 29 May 2013 22:25
You talking like a chin scoop? One that goes under the frame and picks up air from low down?
Last edit: 29 May 2013 22:25 by steell.
- Nebr_Rex
29 May 2013 22:47
Do you mean ram air?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Powerstroke_fan
29 May 2013 23:28
I am wanting like a Y in front of the motor to work as a funnel to funnel all the air onto the motor.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- DoctoRot
30 May 2013 08:42 - 30 May 2013 08:43
like this? it looks pretty trick but i dont know how much it did because you don't find it on any of pop's later bikes
Last edit: 30 May 2013 08:43 by DoctoRot.
- DoctoRot
- Powerstroke_fan
30 May 2013 12:53
That first picture was really close to what i had in mind. Just wasnt thinking about going down and around the pipes like he did.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- djturnz
04 Jun 2013 14:00
Spin the head around and point the carbs forward. It's been done with Twins, might be able to do it with a 4.
1982 KZ750 (4) LTD
- Powerstroke_fan
04 Jun 2013 14:22
what good would that do 4 me? It wont make me run any cooler. Then i would have to get special pipe made and would have to worry about tire hitting carbs and flipping water and dirt in there. It would make it completely unstreetable in my opinion. I just need more air to flow across the head is all i want.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- djturnz
04 Jun 2013 15:44
Oops. There goes reading comprehension. I read it as "I want to get all the air INTO the motor". As in through the carbs. Which explains my confusion with how that sheet metal set-up would funnel air to the carbs.
Just pretend I was never here.
1982 KZ750 (4) LTD
04 Jun 2013 15:52 - 04 Jun 2013 15:53
www.airtech-streamlining.com/vintage/vintagechinscoops.htm
www.airtech-streamlining.com/vintage/vintagebellypan.htm
see if something there don't trip your trigger.
Last edit: 04 Jun 2013 15:53 by 531blackbanshee.
- Powerstroke_fan
04 Jun 2013 16:13
Hey thanks for the links leon. Iam really had something like the first picture doctorot posted. I probably wont make one. But i would like to but money is a little tight till i get my truck fixed.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
