Non USD fork swaps
  • floivanus
  • floivanus's Avatar Topic Author
Non USD fork swaps
25 May 2013 23:09
#589202
Is there an affordable 80 kz1000 ltd fork swap out there that retains much of the stock look but just improves the handling etc?
Dont like the usd look
Past; 78 kz1000, 83 kz550
Andrew
  • 893cv
  • 893cv's Avatar
Re: Non USD fork swaps
26 May 2013 01:35
#589218
Yes, I am using the forks from a YZF600r. They are longer then the stock KZ1000 B4 forks, they are cartridge forks, they are made for a 17mm. axle (the same as your KZ), they are cheep (lots of dead YZF's out there) and Race-Tech makes all the parts you will need to set them up for your KZ.
Attachment IMAG0033_2013-05-26.jpg not found
Attachment IMAG0013.jpg not found
Good luck and please let us know what you use.
1980 kz1000 LTD
1978 Z1R
The following user(s) said Thank You: bluezbike
  • floivanus
26 May 2013 09:54
#589241
What trees did you use?
Andrew
  • 893cv
  • 893cv's Avatar
26 May 2013 14:11
#589266
I made them. I used the stem from an 82 KZ1000, setup the CL's at 200mm. ( same as a stock YZF, so I could use the YZF wheel if I want later on) and 55mm. offset so it will not stear like a truck. Most folks just use modern triples but thats too little offset.
1980 kz1000 LTD
1978 Z1R
