KZ 750 LTD K1 Seat
- Salder69
KZ 750 LTD K1 Seat
22 May 2013 05:57
No eBay APP ID and/or Cert ID defined in Kunena configurationBefore a couple grand
i.imgur.com/Wcdqah.jpg
After a couple grand
i.imgur.com/oDrTh4zh.jpg
Top end full rebuild (had a broken piston ring, valve leaks, etc)
New tank, new wiring harness, new controls, new headlight/blinkers, tuned carbs
Last on my list is a voltage regulator, battery, some LED strip lights/blinkers for the back, and lastly A SEAT!
Okay, I have no idea how the original seat went on, and I can't find the documents to show me how, but from what I understand it was a hinge and latch type setup.
I want to go more for a sportster/cafe racer look without new handle bars, but first, I gotta get a new seat. The rack is staying off and that original seat was Jerry rigged to bolt on to the back rack with no fastening on the front.
If I buy this item -
should it fit? I have a hell of a time figuring out which models can swap what because though these bikes didn't have a super long line of production, they sure as shit had a lot of different models...
Anyways, I'll be continuing to customize it after this, but I need a decent seat for the rest of the riding season.
Thanks for all your help.
- steell
Re: KZ 750 LTD K1 Seat
22 May 2013 12:38 - 22 May 2013 23:03
No that seat won't fit, it's for a 750 twin.
The 750 LTD four has two seats, driver and passenger.
Parts diagram from kawasaki.com
Edited: Dumb mistake on my part. See below.
Last edit: 22 May 2013 23:03 by steell.
The following user(s) said Thank You: Salder69
22 May 2013 14:24
Am thinking the KZ750 LTD-K1 at hand is a 1983 belt drive twin, but am uncertain as to whether the ebay listed seat from a 1978 Kawasaki KZ750 Twin might easily and readily bolt on (but it might).
Checking with kawasaki.com won't help too much because different seat cover patterns get a different part number regardless of being otherwise identical.
- Salder69
22 May 2013 20:25Patton wrote: Am thinking the KZ750 LTD-K1 at hand is a 1983 belt drive twin, but am uncertain as to whether the ebay listed seat from a 1978 Kawasaki KZ750 Twin might easily and readily bolt on (but it might).
yeah, I'm thinking either way, It's gonna take some work no matter if I buy the right seat or the wrong one, I just want to make sure the pan fits snug on the chassis.
Thanks for your help
- steell
22 May 2013 22:59Patton wrote: Am thinking the KZ750 LTD-K1 at hand is a 1983 belt drive twin, but am uncertain as to whether the ebay listed seat from a 1978 Kawasaki KZ750 Twin might easily and readily bolt on (but it might).
Yep, I'm the dummy that's responsible for jumping to conclusions :blush:
That seat is for a 76-80 750 twin. I have had an 82 750M, and I know the earlier seat will not fit an 82, but I don't know if it will fit an 83.
- AtLarge
22 May 2013 23:24
Nope. That seat will not fit an 83. M1 and K1 are practically identical with the exception of the belt drive. Only the 82, 83, and Canadian 84 will interchange.
1973 Honda CL70-K3
1975 Kawasaki 350 F9-C
1983 Kawasaki KZ750-K1
1994 BMW K1100RS
2008 Suzuki GSX1300-BKK8 #1120
1994 BMW K1100RS
22 May 2013 23:47
Might consider starting a topic in KZr Classifieds-Wanted forum.
- Salder69
23 May 2013 03:27AtLarge wrote: Nope. That seat will not fit an 83. M1 and K1 are practically identical with the exception of the belt drive. Only the 82, 83, and Canadian 84 will interchange.
It is a 1983 Kz750 LTD K1 - Belt drive Twin
I would really like to find a seat and have it shipped and on the bike by June 8th
Thanks
- AtLarge
23 May 2013 23:16
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configuration
Maybe you talk this seller into shortening the time on this one?
Or this one is sooner but something about it isn't quite right.
Salder69 wrote:AtLarge wrote: Nope. That seat will not fit an 83. M1 and K1 are practically identical with the exception of the belt drive. Only the 82, 83, and Canadian 84 will interchange.
Thanks
1973 Honda CL70-K3
1994 BMW K1100RS
1994 BMW K1100RS
- Salder69
23 May 2013 23:59
I already contacted the seller on the first one as it is for the exact model and in great condition, and I have to go buy new tires on saturday so when I go to the shop I'll check and make sure the previous owner didn't grind the brackets off the frame, and if he did, the seller agreed to cut his off and send them for $20 extra.
Thanks for the info Bro.
Nice to know there are still helpful people here.
Thanks for the heads up
AtLarge wrote:Salder69 wrote:AtLarge wrote: Nope. That seat will not fit an 83. M1 and K1 are practically identical with the exception of the belt drive. Only the 82, 83, and Canadian 84 will interchange.
Thanks
