Need handlebar for a kz1000J
- Killerkz
15 May 2013 14:23
I have a 82 kz1000J and previous owner put some goofy cafe racer handlebars
I want the original but they are no longer available. What other models had the same style? or where can I buy aftermarket with same bends? Any info or links would be appreciated
thanks
Guz
thanks
Guz
- Killerkz
Re: Need handlebar for a kz1000J
20 May 2013 19:00
Does anyone have a 81-82 that would be kind enough to take measurements? parts on line show that the KZ750E had the same part number
Guz
Guz
- gengomerpyle
20 May 2013 19:13
have you tried ebay? you may find something close at Z1 enterprise.
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
1971 Honda CB750K
- grumpy56
20 May 2013 21:12
Mine (stock) are about 29 1/2" from tip to tip and they have about a 2" rise.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- Killerkz
21 May 2013 00:00
Thanks guys hey grumpy which bar do you think will match the original? The euro or superbike?
www.z1enterprises.com/ItemDetails.aspx?i...Bars&item=EM23-12563
www.z1enterprises.com/ItemDetails.aspx?i...+Bar&item=EM23-12561
- grumpy56
21 May 2013 09:46
Hey KillerKZ. Hard to tell. If I were to guess, I'd say the Superbike.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
21 May 2013 10:07 - 21 May 2013 10:08
Someone over at Z1Enterprises probably knows.
For oem, Partzilla has the following info for the 82 KZ1000-J2. I searched ebbaayy but didn't find anything.
46003-1068 HANDLEBAR
1980 KZ750-E1
1981 KZ1000-J1
1981 KZ750-E2
1982 KZ1000-J2
1982 KZ750-E3
1983 KZ1000-J3
1980 KZ750-E1
1981 KZ1000-J1
1981 KZ750-E2
1982 KZ1000-J2
1982 KZ750-E3
1983 KZ1000-J3
Last edit: 21 May 2013 10:08 by martin_csr.
- Killerkz
21 May 2013 15:46 - 21 May 2013 15:47
Spoke to Chris at Z1 enterprise and he suggested that I get Width , Rise, Pullback and Center Width from an original :blink: He also said they looked more like the kz900 style. Grumpy could I trouble you or anyone to measure the pullback and center width?
Thanks
Thanks
Last edit: 21 May 2013 15:47 by Killerkz.
- grumpy56
24 May 2013 10:32
Martin is accurate with the P/N. Here are the measurements (approximate): Width = 29"; Rise = 2"; Pull Back = 6.5"; Center Width = 5.75". Hope that helps.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
