Front sprocket questino on z 750 E3 1982
- mickelingon
14 May 2013 10:48
Hi
I'm rebuilding a z 750 E3 1982. Or as a matter a fact building a cafe racer.
Does anyone know if a front sprocket for 530 chain will fit on this bike?
Thanks
Mike
Thanks
Mike
- steell
- undiablo
Re: Front sprocket questino on z 750 E3 1982
14 May 2013 14:19
Yes, and the biggest one you can use is a 17 teeth without risk of messing with your clutch/sprocket cover.
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
- mickelingon
15 May 2013 16:29 - 17 May 2013 09:26
Thanks, since 530 is not standard for my bike. It's supposed to be 630.
What model has a 530 that will fit, so I know what to ask for?
The LTD?
//Mike
The LTD?
//Mike
Last edit: 17 May 2013 09:26 by mickelingon. Reason: One mor question
- mickelingon
23 May 2013 09:49
Would check with Z1 Enterprises.
See the Z1E info and several listings under maintenance section for 1982 KZ750-E3:
Click here > www.z1enterprises.com/ShopByCategory.asp...ory=0101010304031101
Goodn Fortune!
Goodn Fortune!
- steell
23 May 2013 11:34mickelingon wrote: Thanks, since 530 is not standard for my bike. It's supposed to be 630.
The LTD?
//Mike
76-80 KZ650
- undiablo
27 May 2013 17:46
530 - 17 teeth max - axle is 13 spline shaft
- mickelingon
16 Jun 2013 06:30
Thanks guys, Will show progress pictures
//Mike
//Mike
