HELP!!!!!!! Cantget shaftie swing arm off
- jarrad
14 May 2013 08:37
Hey guys does anyone know how to get the 2 pins that hold a shaft drive swingarm out?
I have the 3 bolt caps off and can see the pins I had assumed they would have a thread in them
So I could screw something in and pull them out, but nothing???????
I need this off ASAP as someone is coming to pick it up in 2 days.
"IF EVERYONE HAS ONE, I DONT WANT ONE"
79 z1000st BUILD:
www.streetfighters.com.au/for...-OLDSKOOL-quot
R6 build:
www.customfighters.com/forums...ad.php?t=53108
KDX build:
www.dirtrider.net/forums3/sho...d.php?t=166143
79 z1000st BUILD:
R6 build:
KDX build:
- Motor Head
Re: HELP!!!!!!! Cantget shaftie swing arm off
14 May 2013 09:21 - 14 May 2013 10:06
The ones I've pulled, have a boot at the engine bevel gear that needs to be pulled back. Then there's a small band of spring steel around the coupling end, under that there is one pin in a hole. It just pushes in, as it has a spring under it. So I used a small pick, just a easy push in and it releases. Once it slides off of the splines you'll see how it attaches. I would turn the shaft so the hole for the pin faces upwards, so it can't fall out.
Sorry i see you mean the swingarm, probably the pivot pins. They come out after removing th bolts, and then I took a thin tipped pry bar to wedge in behind the flange. Once it moves a bit you can get in behind on each side and pry evenly, and out it should come.
Last edit: 14 May 2013 10:06 by Motor Head.
- havakaw
15 May 2013 22:13
Yeah,there should be threadded holes in the center of the bushings.Maybe somebody had it appart before and put them in backwards.
'80 KZ 750 LTD-H
'82 KZ 1100 A-2 Shafty (ex-bagger)
