Front brake mc replacement
  • sig
  • sig's Avatar Topic Author
11 May 2013 17:39
#586899
I recently bought a used 82 KZ650 H2 CSR. While going through and cleaning/repairing I found the master cylinder was full of yellow crusty stuff and no fluid. Yay. So after scraping it out I tried bleeding the brakes and almost no fluid came out.
This bike sat for years before i bought it. So I need a front brake. Not sure what rebuilding entails and if its worth it. More interested in buying a working part but can't find one in good shape. Needs to be a non-tilted single caliper 1/2" bore with a brake light switch. Doesn't have to be Kawisaki. Any recommendations?
1982 KZ650H CSR
Re: Front brake mc replacement
11 May 2013 17:53
#586902
It sounds like will need to deal with more than the MC if it was that bad. Chances are that the caliper is also full of crap. You may find if you clean up the caliper and MC that the brakes will bleed ok and work for you. Ed
  • martin_csr
  • martin_csr's Avatar
11 May 2013 19:34
#586908
usa-motorcycles-inc on ebbaayy lists new aftermarket mcs. I'll suggest replacing the brake lines w ss braided. I installed Goodridge lines & fittings from Z1Enterpirses.com. I also rebuilt the caliper w a K&L kit & piston from Z1.
  • sig
11 May 2013 23:14
#586950
Thanks for the tip! Just in case do you know any compatible parts from another model?
1982 KZ650H CSR
