drag bars
- kenfowler123
drag bars
04 May 2013 12:27
Have a 82 kz 1100, I am interested in some drag bars. My question is what length do they need to be to accommodate the master brake cylinder and all the stock accessories that go on the stock handlebars?
1982 KAWASAKI KZ 1100 A SHAFT
- Matteson
The following user(s) said Thank You: kenfowler123
- nivlac
Re: drag bars
08 May 2013 05:42
i got a set of drag bars for my 84 kz1100 (pretty much the same bike). I had to put a set of 3" risers on so the master cylinder would clear. They look great. No other changes were required.
1983 kz1100
1979 cb650
1979 cb650
- havakaw
Re: drag bars
08 May 2013 17:34
I went with a set of "Daytona" bars on mine.I had to drill a hole for the right controls to lock into,and reposition the front line off the master 90* up.Other than that,everything workes out.
'80 KZ 750 LTD-H
'82 KZ 1100 A-2 Shafty (ex-bagger)
- dbc92s10
Re: drag bars
08 May 2013 22:15
im runnin super bike bars that are 30in wide, and everything is spaced out perfect changed, to a zx11 master cylinder because of the extreme angle the stock mc would have been put in
81 ltd1000
1135 mtc 10.5/1
cavanaugh racing head
38.6/32 p&p
APE k410 cams
APE hardware and tensioner
84 gpz1100 trans
kerker w comp baffle
rs36 carbs
fast by gast race crank
1135 mtc 10.5/1
38.6/32 p&p
APE k410 cams
84 gpz1100 trans
rs36 carbs
- Kapahulu
Re: drag bars
09 May 2013 04:41 - 09 May 2013 04:46
There are also "broomstick" drag bars which have no bend. They come longer, like 32 inches and then you cut them down to the length that clears the master cylinder and so that the control switches don't hit the gas tank. I have a set. The look takes some getting used to.
Too bad regular drag bars (with the bend) are made so short. If they were 30 inches wide then there would be less problems with clearance.
Here's a picture of a KZ I had with the broomstick handlebar.
2strokeworld.com
2strokeworld.com
Last edit: 09 May 2013 04:46 by Kapahulu.
