squirrley rear end
  • flying dutchman
  • flying dutchman's Avatar Topic Author
squirrley rear end
03 May 2013 10:17
#585417
hey guys. 79 kz-1000-ltd. rear end feels squirrley under hard braking in a straight line. anybody have any ideas on what causes this?
flyingdutchman
79 kz-1000 ltd left to me by my best friend!!
it came in four boxes, frame and engine
i look much better with my helmet on, its full face.
  • kzz1king
  • kzz1king's Avatar
Re: squirrley rear end
03 May 2013 12:24
#585433
Not sure if you are referring to bike in pics but mine did that with loose and broke spokes! Could be wheel bearing too. Wheel cocked in arm.
Wayne
Home built KZ1000 turbo setup
The following user(s) said Thank You: flying dutchman
03 May 2013 13:16 - 03 May 2013 13:17
#585438
What tires; tire sizes; and air pressures are you using and how old are they? (Not Dunlops I hope) Ed
Last edit: 03 May 2013 13:17 by 650ed.
  • MTH76
  • MTH76's Avatar
03 May 2013 13:31
#585440
If you have a center stand, put your bike on it and check your swing arm for any side to side movement.
Also check the wheel while it is raised off of the ground.
This is not a good feeling to have.
Good Luck!
1976 KZ900 1075 head ported,over-sized intake valves shim under bucket Z-4 cam motion cams 34mm RS carbs back cut trans GS1000 swing arm with 3.5" Sun rim MotoGPwerks stainless steel pipe
  • flying dutchman
03 May 2013 19:13
#585492
avon-cobras, 130/90-16. everything on back seems tight, measured and tire runs true. scratching my head.
flying dutchman
  • MFolks
  • MFolks's Avatar
03 May 2013 19:35
#585497
Axle tight? Chain adjusters with same tension? Torque link tight? Bearings in good shape?
03 May 2013 19:38
#585498
Are you applying enough front brake on hard stops? Some guys (not saying this is you) are reluctant to really lay on the front brake during hard stops even on good, dry asphalt. If the rear brake is used as the primary stopper it will break free rather easily as the bike's weight shifts to the front forks. I believe the braking ratio is something like 80% front 20% rear for quickest stops. Ed
  • havakaw
  • havakaw's Avatar
15 May 2013 22:23
#587619
Quit driving so damn fast!!! :woohoo: Check the tire pressure,make sure it's up to spec.
'80 KZ 750 LTD-H
'82 KZ 1100 A-2 Shafty (ex-bagger)
