Fellow swingarm "swappers" I NEED SOME HELP!
- havoc97
02 May 2013 18:19
Ive been messing with this build for a few months and im itching to get the mono rear welded up within the next few weeks.
Swingarm is off of a 01 gxsr600. Width is 9.25" at the pivot tube(the same as the stock kz swingarm)
Having a few different issues....one being this:
[img]http://[URL=http://s99.photobucket.com/user/havoc97/media/KZ%20CAFE%20BUILD/rsz_1rsz_001_zps72ac62f8.jpg.html][IMG]http://i99.photobucket.com/albums/l318/havoc97/KZ%20CAFE%20BUILD/rsz_1rsz_001_zps72ac62f8.jpg[/img][/URL][/img]
Seems like no matter what the dust caps will tweak out of position because the pivot bolt tube in the frame is so much smaller than the dust cap.
Second issue:
It seems like no matter what, even with metal spacers in there it is impossible to get all of the play out of the swingarm so it doesnt move back and forth on the pivot bolt. (yes i have a machined tube inside of the gxsr swinger to take up the gap between the stock 5/8" pivot bolt and the gxsr stock bolt.
[img][URL=http://s99.photobucket.com/user/havoc97/media/KZ%20CAFE%20BUILD/P2211488_zps1cde3643.jpg.html][IMG]http://i99.photobucket.com/albums/l318/havoc97/KZ%20CAFE%20BUILD/P2211488_zps1cde3643.jpg[/img][/URL][/img]
Even with the swinger off of the bike, if i take my hands and place them on each side of the dust cap as firm as possible, you can make the swingarm shift back and forth maybe a bit more than an eighth of an inch. The internal bearings in the arm stick just ever so slightly out past the edge of the pivot tube.
Hopefully these things make sense....I just want to get this damn issue figured out so I can move on to the suspernsion
Second issue:
- havoc97
Re: Fellow swingarm "swappers" I NEED SOME HELP!
02 May 2013 18:23
when you click the first picture it will bring you to photobucket...click it again and you then can click the zoom button to actually see whats going on there
- Haybus
- Big Al
02 May 2013 19:48
Generally you need to mimic the spacers that held everything on the gsxr originally. Was something retaining the seals on the gsxr? Maybe the frame flange compressed the seal/spacer? Can't tell, but it looks like your seal is integrated to the thrust washer/spacer? Does it contact the inner race of the bearing or is it just a cap that sits over the end of the tube? Looks like the inside diameter is smaller than the axle tube flange on your KZ frame allowing the seal to move? If it moves side to side it would seem your spacer isn't long enough. Perhaps you could make a new flanged spacer to take up the play and retain the seal? Takes precise measurements to get it right. Mine only has about 0.002" clearance between the tube/bearings/spacers and the width of the frame. It's a bear to put in and take out if it gets cocked.
1976 KZ900 LTD (sort of)
2005 FJR
2009 Hayabusa
www.kzrider.com/forum/11-projects/557845...-streetfighter-build
2005 FJR
2009 Hayabusa
- steell
02 May 2013 21:22
Stop dealing in inches on a metric motorcycle, close enough does not apply when dealing with stuff like this.
5/8" = 15.875mm
The pivot bolt is in mm (15mm) not 5/8". At least you'll know what is causing the play in your swing arm after you put it together.
5/8" = 15.875mm
- mike0537
03 May 2013 00:03
I used a 1997 gsxr 750 swing arm. Same exact fit as what you are going through. First of all I turned a sleeve in the lathe and pressed it into my swingarm's existing sleeve. The inside I bored out to 5/8". My pivot bolt fits nice and snug inside of my swingarm. The way I solved the problem with it sliding past the dust caps was also very simple. I essentially used large washers and welded them flush with the frame gussets. The washers are the same o.d. as the dust covers. Both problems solved. I didn't take pics of it in my build thread so I can't link you to it. Here is a similar idea as to what I did though.
kzrider.com/forum/11-projects/531667-81-kz750h-project
1980 KZ750E
- mike0537
03 May 2013 00:06
Oh and I may have as much slop in my pivot bolt as you do. I have only been riding my bike for about a week now and it rides smoother than it did stock. I will say I haven't had it above 50mph or so yet though.
Also I am not positive about this but, I remember measuring my pivot bolt at closer to 15.7mm which is why I bored to 5/8"
1980 KZ750E
- Hollywoodmx
03 May 2013 10:52
You need a washer that has a lip which puts pressure on the dust seals. You could also glue the dust seals on..
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- havoc97
06 May 2013 12:45
thanks for all the advice guys. here is what I ended up doing.
1" steel washers with a OD bigger than the dustcaps. Welded them in and it worked perfect. takes up the remaining "slop" i had and puts pressure on the dustcaps keeping them in place. easy fix to the problem.
[img][URL=http://s99.photobucket.com/user/havoc97/media/KZ%20CAFE%20BUILD/P5061516_zps8a4888a8.jpg.html][IMG]http://i99.photobucket.com/albums/l318/havoc97/KZ%20CAFE%20BUILD/P5061516_zps8a4888a8.jpg[/img][/URL][/img]
[img][URL=http://s99.photobucket.com/user/havoc97/media/KZ%20CAFE%20BUILD/P5061517_zpsf73b820f.jpg.html][IMG]http://i99.photobucket.com/albums/l318/havoc97/KZ%20CAFE%20BUILD/P5061517_zpsf73b820f.jpg[/img][/URL][/img]
hope the pics help anyone else who runs into this same problem.
Next up this week, finishing the mono shock conversion
- uglee
- New 2da game but Tru 2this thang!!!!!
08 May 2013 17:09Please Log in or Create an account to join the conversation.
08 May 2013 17:50uglee wrote: Wish I could find on of these.....
www.redlinecycle.com/swingarm%20-%20direct%20fit.html
If you like that one call or PM Les Holt here on the forum. Does top notch work and will make you a swingarm to your specs
- Woody73
11 May 2013 04:36
man you guys keep posting these good post. should make my swap be alot easier once i get out of this damn desert & can work on my bike.
"He knows the ways of the Force. He's been trained to use the Dark Xide. DO NOT Fear the Dark Xide"
2011 Harley Street Glide
