Shock Advice
  • GI
  • GI's Avatar Topic Author
Shock Advice
29 Apr 2013 16:36
#584688
Hi all. It’s been about seven years since I last posted…basically since the last time I needed help. :D After selling my KZ before a move, I finally managed to score another. It’s a 1979 KZ1000 Shaft drive with Vetter fairing, saddle bags and trunk. I’ve been riding it now for a couple of months and now I think I’m ready to change it up a bit to suit my wants.
First order of business is the rear shocks. On my 1996 KZ1000P, I bought an old pair of progressive and had them chopped (I don’t remember by who, but they came recommended at the time) and I loved the look and feel. I was going to head in that direction again (not chopped, but a shorter shock maybe) and would like to know if anyone has any experience with going with a 12” or 11.5” on this type of bike with the luggage. I don’t want to scrape, but I’d like to go as low as I can comfortably go.
I’m thinking of adding an accessory plug (or two) for my phone and changing the seat. I really liked the solo seat from the copcycle, but it doesn’t really fit correctly. I’ll probably have to get some custom work done locally.
Thanks.
Chris
1979 KZ1000 Shaft Drive w/Vetter Luggage
1972 Yamaha JT60
1983 Yamaha DT100
1996 KZ1000P...gone, but not forgotten. ;(
  • drummerjoe10
  • drummerjoe10's Avatar
Re: Shock Advice
30 Apr 2013 01:57
#584844
Lowering a little wouldnt be bad as long as you werent carrying anything super heavy, I lowered my 76 900ltd 2 inches in the rear n i gotta really watch it on any bump over 2 or 3 inches and thats without any bags or passengers. hope this helps
Joe
  • GI
Re: Shock Advice
01 May 2013 13:54
#585119
Hmm, I should probably limit the drop then. I would like to go the whole two inches, but with the weight of the luggage (plus the 60 pounds of “whatever” in them), I think that may be a bit much. Wish there was a way to try them out instead of shelling out a bill or two and risk getting stuck with them.
Did you have a center stand on your 76? I think that hit more often than anything on the police bike.
Thanks for the reply.
1972 Yamaha JT60
1983 Yamaha DT100
  • zukdave
  • zukdave's Avatar
Re: Shock Advice
01 May 2013 16:52
#585139
I think with a two inch drop you will need a lot stiffer spring to keep it of the tire loaded and then be to stiff to ride unloaded.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
