82 GPz750 gearing recommendations
- ThatGPzGuy
28 Apr 2013 08:49
Hey Gang,
I am finally replacing the worn out 630 chain on the GPz. I am going to a 530 o-ring chain and originally wanted to keep the stock gearing because I sometimes commute on it and did not want to turn too many revs at 75 MPH. With the 630 I had 13/33 gears for a ratio of 2.54. With the 530 I can run 17/43 and keep the same gearing or run 15/43 for a ratio of 2.87 for a little better acceleration. Is this too much of a jump? What would be a good compromise for my purposes?
TIA,
Jim
TIA,
Jim
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- slayer61
- KZR FLAG RELAY CARRIER #62
Re: 82 GPz750 gearing recommendations
28 Apr 2013 16:34
Compromise at 16/43 best of both worlds? What ever you choose the chain is going to like the bigger sprockets. Paul
- turboguzzi
28 Apr 2013 16:52
first of all, 520 chains are so good today that its a shame not to use them.
17 to 15 is a huge jump percentage wise, more than 10%. wouldnt go higher by more than 1-2 at the back which equals 2.5-5%
that said, unlike other bikes, mama kawa geared the gpz750 quite short to get good 1/4 mile numbers. maybe check first with this SW?
www.gearingcommander.com/
your bike should be in the DB
- ThatGPzGuy
29 Apr 2013 08:40
Thanks Guys. The gearing commander site was a huge help. I'll probably stick with close to stock gearing. One thing I did notice is that the 17T front sprocket won't work with the GPz chain guard. Do people just take those off?
I'll probably end up with 15/38 set.
Jim
Jim
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- turboguzzi
29 Apr 2013 10:04
most people will not fit a 17, i had to because in my racer i run a very high swingarm angle, so it helps to prevent the chain from rubbing on the top slider and i dont run a guard anyway
would go with a 16 if i was you, a 15 might create a similar problem even with stock suspension setup.
- zukdave
29 Apr 2013 22:32
With my 83 GPz 750 motor I run 16/42 for around town and 1/4 mile racing
and 16/45 for 1/8 mile.
Swing arm will not let me run a 15t front
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- turboguzzi
30 Apr 2013 05:58zukdave wrote: With my 83 GPz 750 motor I run 16/42 for around town and 1/4 mile racing
told ya'
