Clubman handlebar for KZ750 B1 1976
- Winkler
27 Apr 2013 01:18
Hey Guys,
I´m thinking about changing my old original handlebar to a Clubman handlebar cafe racerstyle.
Does anybody have experience with that and which dimensions for the clubman would fit best? Will I also have to shorten the throttle cable and shorten the front brake hose?
Regards Andreas
Regards Andreas
KZ750 B1 1976
- donthaveakawman
Re: Clubman handlebar for KZ750 B1 1976
27 Apr 2013 04:25
throttle cable, wires, brake fluid level?
are your footpegs comfortable?
- Winkler
27 Apr 2013 13:26
Will I have to shorten throttle cable and wires? What do you mean by brake fluid level? Will it be too low?
I have the original footpegs on, will they be needed to be upgraded to something else?
KZ750 B1 1976
- zukdave
27 Apr 2013 21:15
I had clubman bar's on my KZ650 when I first got it
and hated them. The pull back angle hurt my wrist's.
As for the brake fluid level I had to lean the bike and
then turn the bar's to level the master cylinder then fill it.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- donthaveakawman
27 Apr 2013 21:38
I had the drag bars on my ltd and it was uncomfortable, but that is just the ltd.
- zukdave
28 Apr 2013 01:15donthaveakawman wrote: I had the drag bars on my ltd and it was uncomfortable, but that is just the ltd.
And what does that have to do with his question ?
If you don't know a thing about clubman's just shut up.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- 0Z.Z1R Mk2
28 Apr 2013 06:47 - 28 Apr 2013 06:49
No eBay APP ID and/or Cert ID defined in Kunena configurationRecently put a set of clubman bars on the my KH500.
There is no doubt they puts more strain on your wrists and back.
It previously had a set of drag bars..so didn't have to change any cables as such.
As I don't do big runs on the 2t...happy to sacrifice a little pain for looks of the clubman's.
These are the bars I purchased >>>>>>
1976 KH 500 triple
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
1982 GSX 1000S Katana
1983 GSX 1000S Katana
Don't knock my turbo lag - it gives your naturally aspirated a chance..
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
Last edit: 28 Apr 2013 06:49 by 0Z.Z1R Mk2.
- Rainman
- and a little Kaw shall lead them
29 Apr 2013 00:07
clubmans on a 80 KZ750H1 (4 cyl LTD)
The LTD brake reservoir is a good fit with the clubman bars. Slngle disc reservoirs can be found on LTD versions of the 440 twin, 550-4 and later model 750 twin.
The stock cables and brake hose was used with some creative routing. The LTD cables are longer than the cables on a 750 twin so they should work.
Good luck,
Jim
Good luck,
Jim
80 KZ750 H1 - the Kaw calf
79 KZ750 Twin - Miss Nov 2008 KZR calander
79 KZ750 Twin parts bike
78 KZ650 C2 Parts Bike
75 KZ400 Wife's old bike sold
81 KZ440 A2 LTD Wife's new bike
84 Honda 450 Rebel Wife's newest bike
Jim
Quincy,IL
Jim
Quincy,IL
- donthaveakawman
Re: Anyone else get burnt knees on the aircooled fins?
29 Apr 2013 00:12
Anybody else burnt their knee on the side of the kz engine? :dry:
- Rainman
01 May 2013 01:37
Foot pegs, standard footpegs removed along with the lower foot peg post (nut on backside).
Replaced with rear pegs from a 750twin screwed in with spacers to keep from bottoming on the end of thread. Brake and shift levers shortened to suit.
Jim
Quincy,IL
Jim
Quincy,IL
- Winkler
01 May 2013 02:47
Bad ass bike!!
I will definitely buy my own clubmans bar as well!
I want that look on my bike even though it might hurt a bite i the wrist/shoulder after some time.
No pain - No gain
I will post a pic during the summer with the new look.
No pain - No gain
KZ750 B1 1976
- Winkler
01 May 2013 02:54
Hey Jim
What are the dimensions on yours?
Because as I can see from Ebay, there are 2-3 different models in width and pullback angle.
KZ750 B1 1976
