fork oil substitute-atf
  • donthaveakawman
  • donthaveakawman's Avatar Topic Author
19 Apr 2013 04:15
#583049
is it ok to use automatic transmission fluid for topping off my fork oil level. should I just replace the fork oil with automatic transmission fluid.
if so would type f work or should I use the dextron mercron?
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
Re: fork oil substitute-atf
19 Apr 2013 08:09
#583051
I would use fork oil. Its inexpensive and its got anti foaming properties and its diffrent weights.
1977 KZ 1000 work in progress
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
19 Apr 2013 08:31
#583052
I have used ATF in a bike that belonged to a heavy rider. I bought the bike and never changed out the oil and it rode alright. I would use fork oil. Roy
19 Apr 2013 08:37
#583053
I'll put it this way - I don't know anyone who uses fork oil in their automatic transmission. ;)
  • donthaveakawman
19 Apr 2013 08:55
#583057
It's just the matter of the silver color that is always in there, I have replaced the fork oil 2 times now.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
19 Apr 2013 09:11
#583062
Sounds like your bushings are failing or something broke. And you don't just "top off" suspension fluid, you replace it.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • martin_csr
  • martin_csr's Avatar
19 Apr 2013 10:42
#583075
Did you disassemble &/or clean the forks w a solvent before adding the fresh fork oil?
If the seals are leaking, replace them w made in Japan.
  • donthaveakawman
19 Apr 2013 17:13
#583127
I ride in the rain quite a bit.
  • The_Proletariat
  • The_Proletariat's Avatar
  • "Cocaine is a hell of a drug"
19 Apr 2013 21:41
#583178
My service manual specs 5W-20 motor oil as fork oil.
That being said many people use ATF with success in their forks. ATF has some powerful detergents (ever rebuild an automatic transmission? They are spotless inside) lacking in oil and can be useful to keep the forks clean.
I use ATF as fork oil for 200 miles to clean out the forks then I change to motor oil 5W-20
1982 Kawasaki KZ550 LTD
19 Apr 2013 21:45 - 19 Apr 2013 21:47
#583180
The_Proletariat wrote: My service manual specs 5W-20 motor oil as fork oil.
Wow, what manual is that (Clymer, Haynes, Chilton, Kawasaki, other?) I have never seen motor oil recommended in place of fork oil. Ed
Last edit: 19 Apr 2013 21:47 by 650ed.
  • The_Proletariat
19 Apr 2013 21:49
#583184
Kawasaki service manual.
19 Apr 2013 21:54
#583185
That's interesting. All 4 of my Kawasaki manuals specify fork oil, but mine are all 1980 or earlier. Ed
