1978 KZ200 Installing Hydraulic Front Brake
- Jasonkz200
07 Apr 2013 16:40
On the 1978 KZ200 the front brake is simply a cable. Does anyone a hydraulic front brake that is compatible with this bike?? Any help is greatly appreciated.
Re: 1978 KZ200 Installing Hydraulic Front Brake
07 Apr 2013 19:08
If your bike has a drum brake on the front there is no hydraulic master cylinder that will operate it. You might try to find a KZ200 front end with a disk brake and swap its parts with yours. Ed
- Jasonkz200
07 Apr 2013 19:47
The front brake is a disc brake. Only without hydraulics. When I squeeze the lever a cable closes the pads on the disc. I figured that there might be a hydraulic caliper that i can replace with the non-hydraulic caliper. Maybe from a kz400 or kz250. The caliper i have now is mounted in front of the forks. thanks again and thanks ed
07 Apr 2013 22:04 - 07 Apr 2013 22:06
I believe all the KZ250's use a drum brake up front. Making the switch will require a different caliper. KZ400/440's use different rotors, calipers, etc. but you might be able to make the swap if you can get good measurements from someone and if the dimensions of the rotor, caliper mounts, etc. match your bike. Unfortunately, I suspect this will not be a simple project. Ed
Last edit: 07 Apr 2013 22:06 by 650ed.
- Jasonkz200
07 Apr 2013 23:34
Yea thanks. I can always switch out the forks with other ones but that will be expensive.
