ok guys heres the issue...... got a bone stock 1100 with a rock chip in the front right upper tube and it keeps blowing seals. im also wanting to try and get away from the air ride...... any ideas?
Only issue I can see is that those are leading axle forks,changing to a different style may or may not affect steering geometry.
If you just want to keep the same style front end try pming kz10006(Brian) hes a member on here.
