csr1000 brake rotor
- stevie g
csr1000 brake rotor
06 Apr 2013 12:49 - 06 Apr 2013 12:50
Hi All, One of my front discs is cracked so needs replacing and I cannot seem to find anything with the same diameter (270mm) x 5mm wide, does anyone know if any other kawa disc will fit mine ? i have several spare off the likes of KZ650s etc but they are either not the same pattern fixing bolts, too wide or they have been drilled so cannot get them turned down as the drill holes would be too near the edge of the disc, any ideas chaps ? thanks $tevie. CSR1000 M1 1981
stephen g mackay
Last edit: 06 Apr 2013 12:50 by stevie g. Reason: forgot to enter model.
Re: csr1000 brake rotor
06 Apr 2013 13:12
According to Kawasaki.com the only models that used that rotor were the KZ1000-M1 (CSR) (1981)
and KZ1000-M2 (CSR) (1982). You might find one on eBay, or you may be able to replace them both with rotors from EBC if they make them for your model (but those would be rather expensive). Ed
The following user(s) said Thank You: stevie g
- wireman
06 Apr 2013 13:14
Let me do some checking
- wireman
06 Apr 2013 18:48
Ive got one,check your pm box
- gpz1170
07 Apr 2013 23:48
pm sent
don
don
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
- stevie g
09 Apr 2013 17:23
Hi, I didn't check my PM box as I thought I would be automatically notified when I got one. Turns out there's a few in there. Anyway I managed to source some and they're on their way to me now. Thanks to everyone for getting in touch, $tevie
stephen g mackay
