Front drum brakes locking on kz440
- bucky242
05 Apr 2013 15:31
The front drum brakes are locking on my 1980 kz440. Does anyone know of a diagram to help adjust them? Or a quick tip to help out.
Blue 1980 kz440 b1 with clubmans 2 to 2 exhaust rejetted carb.
- wireman
Re: Front drum brakes locking on kz440
05 Apr 2013 15:46 - 05 Apr 2013 15:46
Well heres a picture anyway,you might want to check a manual for how to adjust it anyway.
I would suggest taking it apart and actually cleaning all the moving parts and lubing the parts that need it.
Chances are those drum brakes have had no serious maintenance since it rolled off show room floor,Id also check wheel bearings at same time.
After that Id pull the rear wheel and do the same thing to it.
Attachment 440brake.gif not found
Last edit: 05 Apr 2013 15:46 by wireman.
05 Apr 2013 17:51
If the brake shoes are old, replace them. The adhesive that binds the linings to the shoes can fail over time. A lining can separate from a shoe & get jammed between the shoe & drum, locking the wheel. It happened to me when rolling the bike off the center stand. very lucky.
- CrazyDuck
06 Apr 2013 13:24
All I can suggest for adjusting them is to make sure both brake shoes are being applied evenly. Kind of obvious but you'd be surprised how many times the so called "professional mechanics" in a shop get that wrong.
I can second that! At least make sure they are in perfect condition. You do not want them to come apart.
The emergency brake pads let go on my Porsche and it sounded like a bomb went off.
martin_csr wrote: The adhesive that binds the linings to the shoes can fail over time. A lining can separate from a shoe & get jammed between the shoe & drum, locking the wheel.
Attachment IMG_0021.JPG not found
1976 KZ900
1974 TX500
1978 TT500
2007 Aprilia SXV
1974 TX500
1978 TT500
2007 Aprilia SXV
