anyone have this problem?
  • donthaveakawman
  • Topic Author
  • Visitor
02 Apr 2013 18:06 #580247 by donthaveakawman
anyone have this problem? was created by donthaveakawman
when i got my 4-1 exhaust on the bike I really didn't realiZe that the center stand was rubbing on the chain. has anyone run into this or just now found out about it?
02 Apr 2013 18:16 #580250 by boatdrinks
Replied by boatdrinks on topic anyone have this problem?
Yep, you can fabricate a stop. I'm working on one now. Got the idea from a couple of guys over at KZ650.info. Once complete I'll share some pictures.
Charles
Madison, AL
1978 KZ650 B2A, Luminous Dark Blue
02 Apr 2013 18:50 #580255 by gengomerpyle
Replied by gengomerpyle on topic anyone have this problem?
what exhaust do you have?
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
02 Apr 2013 19:44 #580266 by MFolks
Replied by MFolks on topic anyone have this problem?
When I removed my stock system, I found the same problem you've got. When I installed a Kerker K2S. I sat down, did some thinking, and removed my centerstand, drilling and tapping for a 1/4"-28 bolt with a lock nut, so I can adjust the amount of movement. The up stop touches against the swing arm. I've had this for many years, with no problems.
02 Apr 2013 19:45 #580268 by KraZyRIDER
Replied by KraZyRIDER on topic anyone have this problem?
...Now there's an odd combo for ya. A 4 into 1 pipe and a center stand.
...Usually, when one goes on, the other comes off.
...I'd be curious to know how many have both, or just the one. :)
Mean Green Speed Machine!
1979 KZ 650-C3 (Cafe Project)
1982 GPz 750-R1
1981 GPz 1100-B1
2005 H-D XL1200C
2006 H-D XL1200C
02 Apr 2013 20:10 #580272 by gengomerpyle
kerker here with NO center stand
1982 GPZ750R1 ELR
1971 Honda CB750K
02 Apr 2013 21:18 #580279 by KZJOE900
Replied by KZJOE900 on topic anyone have this problem?
A bit embarassing explaining what this is, but here is a picture of what I used for my used Kerker. Something similair may work on your bike. I just mounted it on the left side muffler mount point. Its a anchor attachment that came with my flat screen TV wall mount, LOL. They give you different styles for differnt types of mounts that vary from brand to brand. This one of the pairs that was not for my TV. I make it a point to save everything. Kept thinking what I can use, and had an hour left before a going for a group ride that day. Was supposed to be temporary, but looks good and works perfect. Didn't have to paint or anything. Just had to enlarge the hole for the mounting bolt. Maybe you can fabricate something from similiar.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
  • donthaveakawman
  • Topic Author
  • Visitor
02 Apr 2013 21:42 #580287 by donthaveakawman
Replied by donthaveakawman on topic anyone have this problem?
gengomerpyle wrote: kerker here with NO center stand
It is very difficult to check your oil level with no center stand. I suggest keeping the pivot bar in there and the stand in an easily accessible spot in case of a disaster.
02 Apr 2013 21:51 #580290 by Haybus
Replied by Haybus on topic anyone have this problem?
Swingarm stand, or paddock stand? I have a T-Rex with replaceable ends so you can use spools or cradle right under the swingarm.
1976 KZ900 LTD (sort of)
2005 FJR
2009 Hayabusa
www.kzrider.com/forum/11-projects/557845...-streetfighter-build
03 Apr 2013 22:23 #580448 by baldy110
Replied by baldy110 on topic anyone have this problem?
I just keep my center stand in the garage and use it when I need to. I check the oil the old fashioned way, stand the bike up with my left hand while looking at the oil window. Been doin it this way for over 30 years now.
The following user(s) said Thank You: Matteson
  • donthaveakawman
  • Topic Author
  • Visitor
03 Apr 2013 23:01 #580470 by donthaveakawman
baldy110 wrote: I just keep my center stand in the garage and use it when I need to. I check the oil the old fashioned way, stand the bike up with my left hand while looking at the oil window. Been doin it this way for over 30 years now.
same here, I usually have a level handy.
02 Aug 2013 01:16 #599503 by mac in mo
Replied by mac in mo on topic anyone have this problem?
I had same issue. Did the search and found this post.Installed a Mac 4-1. Bike is not yet running. Tonight I was looking at it and discovered the chain contacting the centerstand. It took me a minute to figure it out. I used one of the brackets that came with the exhaust and made a stop, very much like the one posted above. It will work until I can come up with something better. It did give me something to hide the exhaust hanger hole with though.
Kevin
1976 KZ900 A4
