Tried & True Modern brake swaps for KZ?
- Hollywoodmx
30 Mar 2013 12:22
I'm looking for a list of possible doner brakes from my KZ forks. I have no interest rebuilding the poor performing stock one. I will be replacing the master cyl as well. I realize this options involve fabbing brackets.
I think I remember reading the early 90s tokicos from a zx6 work on the kz rotors. Are there others?
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- Hollywoodmx
Re: Tried & True Modern brake swaps for KZ?
03 Apr 2013 00:10
Fuck it. I ended up buying a mid 90s zx11 calipers and master as the rotor thickness was close enough.
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- steell
03 Apr 2013 01:09
Will the caliper fit between the disk and the wheel?
The ZX11 guys take the stock calipers off and replace them with Honda F4i Nissin calipers.
- Hollywoodmx
03 Apr 2013 12:08steell wrote: Will the caliper fit between the disk and the wheel?
Doooh! Well they are the same looking as the zx6 which I have already seen those swaps for kz's.
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- steell
04 Apr 2013 00:01
4 piston or 2 piston calipers? I tried 4 piston calipers on the front of a KZ and they would not clear the wheel on the backside. 95-96 GPz1100 has 2 piston calipers that might work, but I don't believe the 4 piston calipers off the ZX11 will.
You can have pretty damn good brakes using bolt on components, if I hit the front brakes on my KZ750 hard one of two things will happen, the front tire will lock up and slide, or it will do a stoppie. And that's using all Kawasaki bolt on components. You really should do some research on brake systems before you start changing things.
- saxjonz
- KawboyZ
04 Apr 2013 01:07
japan.webike.net/KAWASAKI/Z900/457/mtop/
Check these out. Was thinking about doing same thing too.
79 LTD B3
