Cutting the Frame...How Important are those?!
- SuperMoto
28 Mar 2013 01:47
So I have a 79 KZ750 Twin that the previous owner had already started to cut up. I want to cut farther into the frame. Closer to where the rear shock supports actually mount. Is this safe or just a really bad idea? I want to make it into a short single seat and give the look of my rear wheel kind of free floating all by its lonesome. I attached a photo with a line showing the area I want to have the frame stop in. Any input would rock. Thanks guys!
- wireman
Re: Cutting the Frame...How Important are those?!
28 Mar 2013 01:51
The area behind shock mount is only supporting rear seat/fender area,make sure to tie both sides of frame back together after removing rear rear hoop.
- SuperMoto
28 Mar 2013 01:54
I planned on making a nice simple yet tasteful hoop to cover the rear. Also had some ideas about incorporating the tail light into the seat. Ever seen that done?
- wireman
28 Mar 2013 02:10
Never seen a tail light built into a seat,but this place is full of 1sts! :laugh:
- baldy110
28 Mar 2013 17:32 - 28 Mar 2013 17:33wireman wrote: Never seen a tail light built into a seat,but this place is full of 1sts! :laugh:
Will not hurt the frame at all to cut back to there. Just don't start cutting into the shock gusseting.
Last edit: 28 Mar 2013 17:33 by baldy110.
