Are 77 KZ650 front brakes different than a 78 650?
  • pnedac
  • pnedac's Avatar Topic Author
22 Mar 2013 11:52
#578134
I have just picked up a KZ650B 1977 and the front brakes will need to be completely replaced. These are destroyed. I found a good condition caliper but for a 78. Can I still use it? It sure looks the same.
Also, I think I will put a SS brake line with a new front master too. Can I use a master from another model or are the KZs very specific about the brake master? Just curious. Any help is appreciated.
Pnedac
78 KZ650 B
  • wireman
  • wireman's Avatar
Re: Are 77 KZ650 front brakes different than a 78 650?
22 Mar 2013 12:25
#578136
Caliper should be same,worse case scenario you might need to switch caliper bracket.
Any 1/2" master cylinder should work with it. :)
  • baldy110
  • baldy110's Avatar
22 Mar 2013 12:34
#578139
Yes.
  • baldy110
  • baldy110's Avatar
22 Mar 2013 12:34
#578140
Yes they are the same.
  • pnedac
22 Mar 2013 14:03
#578154
Thanks for the advice. I sure appreciate it.
Cheers.
Does anyone know what the difference is between the KZ 650 models of those years 76-81? Mine is a B, but I see that there is a C model and such. Just curious is all.
Thanks,
78 KZ650 B
22 Mar 2013 15:22
#578171
Here is an excellent KZ650 site that describes in detail the differences between the models. Just click on the buttons to the right of the Home button. Ed
jarlef.no/Kawasaki/Series/Z/650/z650.htm
