Will an ST seat fit a Mk II ?
  • greenman43
  • greenman43's Avatar Topic Author
21 Mar 2013 08:33
#577966
Hi all,
I've come across a seat for a Z1000ST, and am wondering if it will fit my A4 Mk II. Different part number from Mr K, but in the diagram it looks the same ... Any help appreciated !
Thanks,
Brian
1980 Z1000 A4 Mk II
2007 ZX10R 'SL' (superlight)
1989 GPz900R
  • RonKZ650
  • RonKZ650's Avatar
Re: Will an ST seat fit a Mk II ?
21 Mar 2013 12:27
#577982
No, The ST is completely different in the way it latches and is bigger all the way around, wider ect.
  • trianglelaguna
  • trianglelaguna's Avatar
21 Mar 2013 12:27
#577983
no they are different and it would take some work if at all
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • Reifer
  • Reifer's Avatar
21 Mar 2013 21:40
#578066
Are the tail pieces different as well?
1974 Z1
1978 kz1000
1979 kz1000
1981 GPz1100
1993 ZX 7
1995 KX 250
2000 ZRX 1100
2002 ZX12
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
21 Mar 2013 23:06
#578075
I believe the tail pieces bolt holes are diffrent. I have both bikes and was going to use the MarkII pieces on the ST but the holes would not line up. Roy
The following user(s) said Thank You: Reifer
  • RonKZ650
  • RonKZ650's Avatar
22 Mar 2013 01:20
#578092
Every part of the ST is different than the MKII. The tail section has indentations for the seat, where the MKII doesn't. Everything on the ST looks same as the MKII, but looks are all that is the same. The MKII used all different pieces.
