KZ triples on a GPZ?
- slayer61
- KZR FLAG RELAY CARRIER #62
17 Mar 2013 22:05 - 17 Mar 2013 22:09
So in an effort to change things up a little on my wife's little gpz, I want to be able to use standard tubular handle bars in place of the oem cast devices. Can I swap out the upper triple clamp on the gpz with one from a kz? Thanks in advance for your help. Paul
Sorry. Just now realize this was posted in engine section not chassis section! Oops!
Last edit: 17 Mar 2013 22:09 by slayer61. Reason: wrong section
- gpz1170
Re: KZ triples on a GPZ?
18 Mar 2013 14:23
slayer61
I've drilled the top triple tree for risers, then used tubular bars.
don
don
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
- gengomerpyle
18 Mar 2013 15:00 - 18 Mar 2013 15:02
if you have a 750r1 the top tree from a 1984 kz700 and a 1982 750L3 will work. im going to do to do the same on mine once i find one.
what you can do is go to the kawasaki site and cross reference the lower tree part number and see what other models use it and go from there.
gpz1170 wrote: slayer61
don
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
1971 Honda CB750K
Last edit: 18 Mar 2013 15:02 by gengomerpyle.
- turboguzzi
18 Mar 2013 15:49+1gpz1170 wrote: slayer61
don
