rear brake rebuild failed
- mark1122
- Keep twisting it
28 Jun 2006 05:10
I just rebuilt my rear master because there was no fluid left in it after my bike sat for 22 years. I blead the system and I got all the air out.The brakes seemed to work on the center stand, But when i took it for a test drive the brakes don't work under load.Is this a symtom of air in the lines still?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- wireman
- BSKZ650
Re: rear brake rebuild failed
28 Jun 2006 09:37
the master cyl is a pian in the butt to get all the air out, still messing with mine after a rebuild
77 ltd1000, current rider
76 kz900, just waiting
- rattler
28 Jun 2006 21:12
if you keep bleeding the rear brake and have no luck, you might want to take a good look at the rear brakehose if it has been setting that long.
- mark1122
- Keep twisting it
28 Jun 2006 22:57
I put a new stainless line on allready. I blead them again today.I got some more air out but there still not up to par.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- gpzrox
29 Jun 2006 02:57
Waitaminute. Just a question, and I am sure that you have addressed it, but what rear pads are you using? The originals, or a newer set? Could maybe, just maybe, need a break in on new pads, or maybe knocking the glaze off of the rotor might help.
Just a couple of thoughts, I didn't see this addressed in the previous posts.
Louie
Louie
84 GPZ750. Modded with stock Kawasaki parts: ZR-7 shock, ZX-6 coils, GPZ1100 throttle, EN454 brake, GPZ900 fuse box, etc. and non stock: Ken Sears mirrors, K&N filter, Pirelli Sport Demons.
- Biquetoast
- King Jeremy The Wicked
29 Jun 2006 04:59
mark1122 wrote:
My current method involved alot of tapping (gently, of course) and waiting. Sometimes, when I *think* I have it right (but don't), I take it for a spin around the block. When I come back, more air comes out.
Oh, and I recently have changed to a "squeeze like crazy" method for bleeding. Fast and furious squeezing seems to get those tiny bubbles out, as they don't seem to progress with slow methodical squeezing....
I hate bleeding brakes...
:pinch:
Yep, this has happened to me. I now swear by "speed bleeders", but I still am not the best at getting all the air out the first time.I put a new stainless line on allready. I blead them again today.I got some more air out but there still not up to par.
:pinch:
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- RomSpaceKnight
29 Jun 2006 11:07
Took me maybe 3 hours to bleed the hydraulic clutch on my zx1100. Then within 5 min went from soft as hell to bang on. My method for brakes is plastic tube over bleed nipple to jar of fluid. Pump lever moderate speed till it stiffens up then have buddy quickly crack nipple and just as quick close. This is done with me holding lever in. Ensure reservior does not go empty. A turkey baster will draw fresh fluid thru quick but have always had to resort to bleed proc. I hate bleeding hydraulic systems. Never as easy as manual makes it out to be. Long drawn out process involving lots of fluid.
- mark1122
- Keep twisting it
29 Jun 2006 22:25
GPZROX. These are old pads. what do you mean by knock the glaze off the rotors? I first tried the fast and furious method then when I didn't see any more air I whent to the pump up the preasure meathod.I'll give it another go on the weekend.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- gpzrox
30 Jun 2006 02:46
What I am thinking is the pads could have become rock hard over the years, and very possibly very smooth and slick, like a piece of glass. No bite to them.
Auto parts stores used to "turn" or "cut" rotors, grinding a small amount off of the surface to get a fresh surface for the pads to bite on. Usually this was because of grooves, but in some cases, the brakes had gotten overheated, and the surface of the rotor -ummmmm- crystalized, I guess you could say, got hard and didn't offer as good of a place for the pads to bite.
I just erased a whole tech witeup on brakes, but I would say: Get new pads. Cheap and easy, you aready have the rest of the work done: lines and m/c.
Cool?
Cool?
- KZ_Rage
- Kentucky Bourbon Barrel Ale
30 Jun 2006 05:20
Are you using DOT 3, 4 or 5?
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
1984 KZ550F2 SOLD!
- mark1122
- Keep twisting it
06 Jul 2006 20:03
dot 5. I blead them again and there working. i can lock it up now.But i would like it to be more sensitive and less travel on the peddle.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
