76 KZ 750 Twin Front Brake Line
  • 89RRando
  • 89RRando's Avatar Topic Author
12 Mar 2013 15:45
#576691
Hello all,
I am building a 76 KZ750 bobber and I am looking to get a new set of brake lines made, but I have a few questions before I get a set made. The question I have is for the front brake line. The current line that is on there is a Three piece line and has several bad spots, and has a steal line that connects it to the front caliper. What I want to know is if I can replace the entire front brake line with a one piece rubber line with banjo bolts on each end instead of having a steal line on the caliper end? I know that putting in a one piece line will eliminate the front pressure switch for the brake lights, but I am ordering a new master cyclender that has a built in pressure switch. Any help would be great!
Thanks Randy
  • wireman
  • wireman's Avatar
Re: 76 KZ 750 Twin Front Brake Line
12 Mar 2013 18:09
#576699
yes you can do that B)
13 Mar 2013 02:02
#576769
Would search brake hose at Z1 Enterprises,
www.z1enterprises.com/ListItems.aspx?keywords=brake+hose
or just give 'em a call as to availability of the length desired.
Good Fortune! :)
