handlebar mounts
  • tugboatmatt
  • tugboatmatt's Avatar Topic Author
handlebar mounts
10 Mar 2013 17:47
#576391
has anybody replaced the mounts and clamps on a kz 440 recently? anyone know a good aftermarket part that will fit a 1980 kz440?
Re: handlebar mounts
10 Mar 2013 18:08
#576394
Why aftermarket; what is it you are trying to do? Ed
  • tugboatmatt
11 Mar 2013 20:24
#576573
Well I've been trying to find new factory mounts but it seems like none of the kawasaki dealers in near me carry any kz parts or parts for models older than 1984. my current mounts are old, shitty and wont keep my handlebars straight for more than a few rides. its just annoying when i get onto my bike and i have to hold my bars cocked to one side to make the bike go straight. I saw some mounts online that were one solid piece, I don't know if that could help the issue or not but I also don't know whether they will fit. I am making my bike into a cafe racer btw.
11 Mar 2013 21:16 - 11 Mar 2013 21:16
#576575
Here's the 1980 KZ440 diagram. The parts (#2 & #3) are still "Active" so any dealer can order them. If your dealer won't tell him to take a hike and order from ronayers.com - just go to that site and plug in the part numbers at the "Search" box. Ed
Attachment 00000_2013-03-11.jpg not found
Last edit: 11 Mar 2013 21:16 by 650ed.
The following user(s) said Thank You: tugboatmatt
  • steell
  • steell's Avatar
12 Mar 2013 14:45
#576681
Why don't you just replace the rubber mounts with new ones? That should fix the problem.
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
12 Mar 2013 15:21
#576686
tugboatmatt wrote: my current mounts are old, shitty and wont keep my handlebars straight
I went through a similiar situation a couple of years ago on a XT500 based flattrack racer. I turned a couple of aluminum slugs that fit where the rubber plugs went and then welded them into place. Problem solved! B)
13 Mar 2013 01:56
#576767
+1 to steell's suggestion :cheer:
kawasaki.com shows the rubber dampers part #92075-039 ere used on 53 different models and are "active" which denotes availability through your friendly local Kawasaki dealer.
Good Fortune! :)
  • Hollywoodmx
  • Hollywoodmx's Avatar
13 Mar 2013 11:15
#576799
If the bars are 7/8s might be able to use dirt bike ones, tonnes of stuff there.
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
