fork oil level
  • dbc92s10
  • dbc92s10's Avatar Topic Author
fork oil level
07 Mar 2013 22:10 - 07 Mar 2013 22:11
#575892
i am rebuilding my 81 ltd1000 forks and was checking in the manual and notice that the ltd and the csr oil level is 7.2 and the 1000j is 4.3 why is the oil level so much higher in the cruizers i thought the forks were the same thanks
81 ltd1000
1135 mtc 10.5/1
cavanaugh racing head
38.6/32 p&p
APE k410 cams
APE hardware and tensioner
84 gpz1100 trans
kerker w comp baffle
rs36 carbs
fast by gast race crank
Last edit: 07 Mar 2013 22:11 by dbc92s10.
  • TexasKZ
  • TexasKZ's Avatar
  • Away
Re: fork oil level
08 Mar 2013 14:13
#575975
The forks are quite different.
