Changing out the hoop
- LeePalmer79
07 Mar 2013 07:00
hey I have a 78 kz650-b2 withe the wire rims and i was thinking of taking off the stock outer hoop and puttin on a 21" one. then I didnt know if that would work or not .. Any thoughts ??
- wireman
Re: Changing out the hoop
07 Mar 2013 08:10
Youll need new spokes,check your clearance between wheel/motor
07 Mar 2013 09:30 - 07 Mar 2013 09:30
Last edit: 07 Mar 2013 09:30 by 650ed.
07 Mar 2013 11:18Likely need to raise the fender in order to allow sufficient tire clearance.LeePalmer79 wrote: hey I have a 78 kz650-b2 withe the wire rims and i was thinking of taking off the stock outer hoop and puttin on a 21" one. then I didnt know if that would work or not .. Any thoughts ??
Or just run without the fender.
You know -- like Ed's 650 Beezer. :lol:
- LeePalmer79
07 Mar 2013 17:13
no no racing... I am doing the mono shock and an air ride in the back. I just like the big rim look in the front and the wide in the back. I was figuring that i would eather have to cut the fender struts and rase it or just leave it off all together. Can any one tell me the size of the hub so I can just do some math to figure out the spoke size?? I guess I can just add the extra to what ever i have now right? Well thank you for your help have a great day..
- wireman
07 Mar 2013 17:20
Go to buchanon.com,they sell rims/spoke kits
- LeePalmer79
07 Mar 2013 17:30
I looked there and all i found was a 19" rim kit.. But i might have missed the spot and will look again. thank you fo the info
