Cruddy master cylinder
  • 3cav84a
  • 3cav84a's Avatar Topic Author
05 Mar 2013 20:39
#575506
G'day, I just pulled apart the cruddiest master cylinder I have ever seen, it looks like it has never had the fluid changed since 1977. It is a KZ 650. I am in the process of deciding whether I can resurrect it but I feel that the cost of a repair kit won't be enough as it looks like the cylinder bore needs a stainless steel insert or maybe I could get away with a bore.
When I pulled it apart I was wondering what the role of the diaphragm was. It must allow the brake fluid to pass thru it, I thought maybe it won't allow moisture to pass thru it?
Has anyone fitted a second hand master cylinder or an after market one and did it operate properly? regards Neil
1977 KZ 1000 A1
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: Cruddy master cylinder
05 Mar 2013 21:13 - 08 May 2013 00:09
#575520
Is
Last edit: 08 May 2013 00:09 by 4TheKZ1000.
  • 3cav84a
06 Mar 2013 02:12
#575593
Yeah that's the one but it didn't look schmick like that one, gee it was in a horrible state I should have taken pictures of it
1977 KZ 1000 A1
  • bluej58
  • bluej58's Avatar
06 Mar 2013 10:22
#575609
This is off a kz1000 A2A but it is the same principle
78 KZ1000 A2A
The following user(s) said Thank You: 3cav84a
  • 3cav84a
09 Mar 2013 19:08
#576204
4TheKZ1000, These look great I have sent you a PM regarding these Master cylinders regards Neil
1977 KZ 1000 A1
