forks
Re: forks
24 Mar 2013 17:14 - 24 Mar 2013 17:14
#578562
gengomerpyle wrote: are they threaded in or pressed? how does using double nuts take it out?
Here's how:
Last edit: 24 Mar 2013 17:14 by 650ed.
  • gengomerpyle
  • gengomerpyle's Avatar Topic Author
Re: forks
24 Mar 2013 18:15
#578585
ok, thanks
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
  • gengomerpyle
Re: forks
25 Mar 2013 16:28
#578718
well ive been spraying penetrating oil on the stud all weekend and letting it sit. i just now put a vice grip on to see if it would come out. well it did and it came out real easily. now i have to wait for the replacement to show up and hope its the same one. thanks for all your help.
1982 GPZ750R1 ELR
1971 Honda CB750K
Re: forks
25 Mar 2013 16:34
#578719
You can use the double-nut trick to install the new studs. That way you won't need to worry about the vise-grips damaging the new threads. Ed
  • gengomerpyle
Re: forks
25 Mar 2013 16:49
#578720
that sounds like a plan :). ill hit ace hardware when the stud comes so i can get the correct size (8mm)
1982 GPZ750R1 ELR
1971 Honda CB750K
  • gengomerpyle
Re: forks
30 Mar 2013 16:54
#579626
well the new stud is longer then the old one. the unthreaded part is about 1/4 longer then the old one. i got a 8x35mm. do you think an 8x28.5 would be a better fit?
1982 GPZ750R1 ELR
1971 Honda CB750K
