crash bars
- donthaveakawman
crash bars
28 Feb 2013 19:24
got a one piece steel crashbar that was bent to high hell. it looks like someone tried to straighten it with a torch-the chrome looks burnt.
I was going to try to find some of the side cover style crashbars, I don't know what they are called.
the one piece crash bar thay I have is snug over the exhaust that I have on there and I layed it down on it a couple of times.
maybe it is time for something different.
- MFolks
Re: crash bars
28 Feb 2013 20:16
Probably what you want, are called "Case Savers".
www.redlinecycle.com
and maybe
www.fastfrom
thepast.com might have them. Also
www.reproductiondecals.com
and
www.americanclassix.com
- Zedone
Re: crash bars
01 Mar 2013 00:28
I've found these to be interesting, from K Factory in Japan... they have some trick parts available. These are CNCed from delrin. They would work well in a lighter impact or tip-over imo. Cheers Doug
1977 KZ1000A1
1977 KZ1000A1 (Superbike Project)
1969 Chevrolet C/10 Short Fleet
- donthaveakawman
Re: crash bars
01 Mar 2013 00:46
mostly worried about the engine/gas tank area the one I have is good for putting my feet up on the road(lazyrider) I think I will look for some case savers though.
Re: crash bars
01 Mar 2013 11:03 - 01 Mar 2013 11:05
You can use the case savers from any KZ650 & most KZ750-4s (mayabe not a GPz or L3 - not sure. ).
Also, according to an MCEnterpirses fitment chart that came w my case guards, most KZ550s as well.
550/650/750-4. Standard, SR, CSR, Ltd, Spectre. (not the 750-Twins - the mounting points are different).
Last edit: 01 Mar 2013 11:05 by martin_csr.
