Rotor size, need help
  • Goalieguy35
  • Goalieguy35's Avatar Topic Author
  • JJ
21 Feb 2013 20:51
#573507
I have a set of blue mags on a 1979 kz 1000 bike i bought but do not think they are off a 1000 for a few reasons. I took the brake calipers off the bike and when i took the pads out i noticed only half of the pad was being worn. So either its the wrong brakes or rotors but when i compared the rotor size to another 1000 i had they were smaller. The disk size on the 79 1000 with blue mags are about 10 inches in diameter and have a 7 allen head bolt holding the disk on with a inner diameter of about 5 inches. Can any one tell me what wheel on what model comes standard with dual disks with the rotor size i described with the 7 bolt pattern?
1982 Kz750 w/ inverted gsxr front end. (sold) but forever missed
1980 z1000 cafe project w/76kz900 motor in it
80 kz 1000
81 kz1000
79 Yamaha xs 650
1979 kz 1000 LTD
1977 kz 1000 A
1977 kz 650 C
1978 kz 650
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: Rotor size, need help
21 Feb 2013 20:59 - 21 Feb 2013 21:01
#573510
It should look close to this one.
Last edit: 21 Feb 2013 21:01 by 4TheKZ1000.
  • Goalieguy35
  • JJ
21 Feb 2013 21:27
#573514
Those are 1000 rotors. I just figured out with a good friend of mine who is into the kz's too and they are gpz wheels. I just need to know what size and year it is to compare so i can get the appropriate brakes for it. I hope someone on here has a gpz they can compare rotor sizes too.
80 kz 1000
81 kz1000
79 Yamaha xs 650
1979 kz 1000 LTD
1977 kz 1000 A
1977 kz 650 C
1978 kz 650
  • steell
  • steell's Avatar
22 Feb 2013 15:02
#573585
GPz750 rotors are 10", GPz1100 rotors are larger, but I don't remember how much larger.
  • OnkelB
  • OnkelB's Avatar
22 Feb 2013 17:51
#573603
GPz 1100 B1/B2 front rotors are 270 mm/10.629", UniTrak rotors are 260 mm/10.236" - both are 5 mm thick with a 4 mm service limit.
77 KZ 650 B1, 82 GPz 1100 B2.
The following user(s) said Thank You: 4TheKZ1000
