Touring gear to fit KZ1000?
- Galactica
21 Feb 2013 02:49 - 21 Feb 2013 02:53
Hi all,
I have 3 Z's. A '73 Z1 that I am nearing completion of the restoration, a '76 KZ900 that is quite nice, and a very nice '77 KZ1000.
I really need a bike with hard bags that I can tour with. My plan had been that when the '73 Z1 was finished, I would sell the KZ900 and KZ1000, then get a modern bike like a Vstrom.
My wife has mandated that 3 bikes is the limit, and I am having a hard time letting go of the Z's.
So here's the thing.... I'd like to set up my KZ1000 for touring. But figuring out a setup for hard bags is difficult. Anyone out there with a KZ1000 police bike that could send me pics of the hard bag system so I could manufacture something? Or does anyone know of andy manufactured systems to fit a 77 KZ1000.
I'm looking for a locking hard bag and top box system.
Thanks.
Cheers,
Ross
Thanks.
Cheers,
Ross
77KZ1000
76 KZ900
76 KZ900
Last edit: 21 Feb 2013 02:53 by Galactica.
- wireman
Re: Touring gear to fit KZ1000?
21 Feb 2013 10:13
I know where theres a 77 kz1000 Ive been trying to buy for close to 20 years with the full vetter package on it,If he ever sells me that bike Ill list the bags/fairing up here for you guys to fight over! :laugh:
- Motor Head
21 Feb 2013 10:34 - 21 Feb 2013 10:37Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/kzride5/public_html/libraries/kunena/src/BBCode/KunenaBBCode.php on line 314. Please enable debug mode for more information.
- Galactica
22 Feb 2013 18:54
I was hoping someone on the forum would be kind enough to post pics of mounting brackets and hard bags so I could construct some myself.
Cheers,
Ross
Cheers,
Ross
77KZ1000
76 KZ900
76 KZ900
22 Feb 2013 19:34Galactica wrote: I was hoping someone on the forum would be kind enough to post pics of mounting brackets and hard bags so I could construct some myself.
Cheers,
Ross
Presumably referring to construction of the mounts, but not construction of the bags, as it is rare to hear of constructing diy hard bags.
Typically, each particular hard bag design -- and there are several -- will require its own unique mount design.
The Vetter bags and mount that fit large Kaw fours appear on ebay from time to time.
As do other bag/mount iterations.
22 Feb 2013 19:45
kawasaki.com doesn't list a '77 Police, but the 1978 KZ1000-C1 (Police 1000) section has a parts diagram for GUARDS/SADDLE BAGS/WINDSHIELD.
If needed, there's a link in my sig for help navigating kawasaki.com
- Galactica
23 Feb 2013 00:06
Thanks Patton, I'll take a look.
Ross
Ross
77KZ1000
76 KZ900
76 KZ900
- 893cv
25 Feb 2013 13:02
Ross,
Take a look at some of the aluminum bag systems that the adventure bike guys use.
www.jesseluggage.com/klr600-650.html
www.motomachines.com/Alu-Standard_c_26.html
www.happy-trail.com/
These bags are very well made and will last through several bikes.
If you like black luggage the Givi bags are great. I have a set on my FJ1200 and my wife has a set on her TDM.
www.giviusa.com/
Givi sells the hardware needed to make a custom mount system work on any bike.
www.giviusa.com/
1980 kz1000 LTD
1978 Z1R
1978 Z1R
- Galactica
26 Feb 2013 22:28
893cv,
Thanks. I will certainly take a look at current stuff. The issue is, designing and constructing the mounting bracketry, to fit the stock mounting points. The bikes I have are really nice stock machines and I am not willing to modify them. The bike I tour on is my 77 KZ1000.
I had a look ad the 78 police bike parts fiche to see if that would help. No joy. The police bike frame has completely different mounting points.
I'm hoping someone here can post pics of the mounts from something like an old Vetter setup. Then I could construct a mounting frame, bearing in mind that I'd likely use a modern set of hard bags and top box to be attached.
Ive been using a cheap set of soft side panniers. But I need something that locks, and locks onto the bike.
Cheers,
Ross
Cheers,
Ross
77KZ1000
76 KZ900
76 KZ900
- Motor Head
26 Feb 2013 23:56Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/kzride5/public_html/libraries/kunena/src/BBCode/KunenaBBCode.php on line 314. Please enable debug mode for more information.
27 Feb 2013 00:34 - 27 Feb 2013 00:36
These links might include helpful pics:
Allow a few moments to appear on-screen.
www.craigvetter.com/images/Vetter%20Fair...20Windjammer%20V.pdf
www.craigvetter.com/images/Vetter%20Fair...ndjammer%20mount.pdf
www.craigvetter.com/images/Vetter%20Fair...20WJ%20SS%20inst.pdf
kz900.com/vetter_windjammer.html
Several years ago, Samsonite and Krause also offered some good aftermarket saddle bags with bike-specific mounting hardware.
Last edit: 27 Feb 2013 00:36 by Patton.
- RonKZ650
27 Feb 2013 02:10
If you're dead set on hard bags, that's fine, but they are not necessary for touring. I rode a lot of tours on a KZ1000, and you can tie a lot of stuff on the seat behind you. I actually tied 140 LBs of luggage on the USA 4 corners tour using bungees. Now if the wife is along, then yes you need bags most likely, otherwise it can be done easily without the addition of any hard bags.
