Swing arm mod, old to new idea for feedback
20 Feb 2013 11:53 - 25 Feb 2013 04:18 #573313 by Hollywoodmx
Swing arm mod, old to new idea for feedback was created by Hollywoodmx
So my machinist is stuck cause his machine is down so my swing arm isn't done. I was thinking of this idea. Could you not cut the pivot tube of a the z swing arm. Weld up the gap from cutting it. Then insert into the new swing arm tube and either let it float on the bearings (if wide enough) or make a couple simple spacers, may be even weld it in?
Thoughts?
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Last edit: 25 Feb 2013 04:18 by Hollywoodmx.
  • wireman
20 Feb 2013 17:57 #573337 by wireman
Replied by wireman on topic Swing arm mod, old to new idea for feedback
That went right over my head! :woohoo:
Can you explain that a little slower? :laugh:
22 Feb 2013 00:31 - 22 Feb 2013 00:32 #573528 by Hollywoodmx
Replied by Hollywoodmx on topic Swing arm mod, old to new idea for feedback
1. take the z swing arm and cut the pivot tube off the rest of it.
2. Weld a block plate on the tube to fill the gap left by cutting the tube portion off.
3. Take tube and insert into the modern swing arm tube by one of the following;
3a. Might get lucky and the z tube will float on the modern swing arm pivot bearings.
3b. Buy bearings that fit on the modern swingarm from a ID diameter to pivot tube OD.
3c. Make a fixed spacer (large washer type) to do the same as 3b but might as well weld it in too.
The reason for exploring this idea is that you can maintain the z pivot bolt and bearings and while it sounds complicated its actually pretty easy.
Anyone have a old swing arm tube to sell to me? :)
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Last edit: 22 Feb 2013 00:32 by Hollywoodmx.
  • wireman
22 Feb 2013 00:47 #573533 by wireman
pm kz1006 B)
22 Feb 2013 01:19 #573538 by les holt
Replied by les holt on topic Swing arm mod, old to new idea for feedback
I've cut the head tube out of old arms and used them to build off of, much easier, cheaper, and better to just build all new. When you weld the old head tube in it warps and won't be the same. My bearing bores are machined only after all the welding is done to insure they are in line.
Les
The following user(s) said Thank You: saxjonz, wireman
22 Feb 2013 01:36 - 22 Feb 2013 01:37 #573539 by Hollywoodmx
les holt wrote: I've cut the head tube out of old arms and used them to build off of, much easier, cheaper, and better to just build all new. When you weld the old head tube in it warps and won't be the same. My bearing bores are machined only after all the welding is done to insure they are in line.
Les
Ah ok. But it did get me thinking. Instead of your mushroom cap idea why don't I just get bearing with the ID of the modern pivot tube with ID of the z1 pivot bolt? Then all I need machined is the length of the modern pivot tube.
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Last edit: 22 Feb 2013 01:37 by Hollywoodmx.
  • wireman
22 Feb 2013 01:53 #573541 by wireman
How about just having bushings with an O.D that fit the I.D of whatever swingarm pivot youre using,then ream the I.D of the bushings to fit the stock kaw pivot bolt sleeve? B)
23 Feb 2013 00:33 #573648 by Hollywoodmx
wireman wrote: How about just having bushings with an O.D that fit the I.D of whatever swingarm pivot youre using,then ream the I.D of the bushings to fit the stock kaw pivot bolt sleeve? B)
That's what I said. lol. :woohoo:
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
  • wireman
23 Feb 2013 04:47 #573668 by wireman
Im talking about using bronze bushings in place of needle bearings in swingarm like they used back in the day with the existing pivot tube in whatever swing arm you use though,no need to cut up a swingarm that way.
Bushings got a bad wrap back in the day mostly because nobody ever greased them,its easy enough to have bushings made up the same length as double needle bearing cages would be B)
  • wireman
23 Feb 2013 04:53 #573670 by wireman
Attachment z1-swingarm-bushes.jpg not found
Something like these but in whatever O.D and length you need to fit new swingarm B)
23 Feb 2013 17:19 #573729 by Hollywoodmx
Oh I gotcha. Well I will look at that option if I cant just buy the right bearing.
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
24 Feb 2013 23:21 - 24 Feb 2013 23:22 #573969 by Hollywoodmx
Thanks man your posts did get me thinking so we ended up doing this which was super easy... Highlights from what's posted in my project thread.
Attachment 20130224_165740_2013-02-24.jpg not found
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Last edit: 24 Feb 2013 23:22 by Hollywoodmx.
