80' KZ750 LTD Frame
  • kznuke
  • kznuke's Avatar Topic Author
80' KZ750 LTD Frame
26 Jun 2006 12:47
#57288
I've been reading lots of archived threads on GS1100 swingarm swap-outs but all I've seen are in regards to 650s or 900s. As far as pivot bolts/axles, bearings, bushings etc. will the same principals apply for the above mentioned bike? Are the 650 and 750 frames that much different? Any help will be appreciated 'cause I just found a swingarm and I'd like too start on it soon. Thanks!!!
  • JMKZHI
  • JMKZHI's Avatar
Re: .
26 Jun 2006 16:44 - 03 Dec 2008 19:12
#57335
del
Last edit: 03 Dec 2008 19:12 by JMKZHI.
  • kznuke
Re: 80' KZ750 LTD Frame
26 Jun 2006 17:24
#57344
Thanks JM! I'll start there.
  • DanOz7Five0
  • DanOz7Five0's Avatar
27 Jun 2006 17:57
#57605
I can add that a 80 750 (4) LTD swingarm will fit a 77 650B frame. There arm is different though, only because the B model has drums and the LTD has a disc.
  • kznuke
04 Jul 2006 22:10
#59412
Thanks D. Saved me some time. BTW, just read your latest post. After all the work you've done to your 650, I can't believe you even thought of giving it up. Some of your prior posts gave me inspiration to try some things I've never done before. You'll get it done I'm sure. (PS - I'm about to start a swingarm install so when I sound like I'm going nuts and ready to quit, I expect the same in return).
