KZ750 rear master on a '04 GSX-R rear brake.
- w8lifter21
- Automotive Afficianado
12 Feb 2013 10:10
In the process of swapping an '04 GSXR rear swing arm on the bike, and it's time to think about the brake. Anyone for see a problem using the KZ master to drive the rear brake? Any reason I should swap to a GSXR master?
'82 Kawayamazuki 750 (KZ750)
'91 300zx Twin Turbo
'96 Maxima
'96 Maxima
- donthaveakawman
- w8lifter21
Re: KZ750 rear master on a '04 GSX-R rear brake.
12 Feb 2013 12:11
As a whole, yes it has a 180 rear wheel. The rotors themselves have a comparable amount of surface area where the brake pads touch, if anything the GSXR has a little less.
'96 Maxima
'96 Maxima
- StreetfighterKz
12 Feb 2013 13:39
You need to find out the M/C bore of the Gsxr unit and compare it to your stock one. If they are the same, no biggie. If they're different, then your rear brake feel will be different...and not guaranteed in a positive way.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- w8lifter21
12 Feb 2013 15:30
Thanks Doug ill check into that.
Jay
Jay
'96 Maxima
'96 Maxima
- donthaveakawman
12 Feb 2013 21:15
I don't see why anyone would put a stretched swingarm on one of these, as though there wasn't already an issue with the tire spinning.
