GPZ900 Swingarm swap to ZZR1100c for wider tyre
  • Driv3r
  • Driv3r's Avatar Topic Author
11 Feb 2013 09:19
#571907
Anyone knows the widest tyre size I can fit into zzr1100 swingarm on GPZ900?
____________________________________
Order is for idiots; genius can handle chaos
  • steell
  • steell's Avatar
Re: GPZ900 Swingarm swap to ZZR1100c for wider tyre
11 Feb 2013 14:31 - 11 Feb 2013 14:33
#571949
I have a ZX1100C (ZZR1100C elsewhere) that has a 200/17 on it, on a 5.5" rim. 180 is plenty big enough for the 11.
Last edit: 11 Feb 2013 14:33 by steell.
  • Lorcan
  • Lorcan's Avatar
  • Speed Loony
11 Feb 2013 14:43
#571951
Probably 180, but the limit will be chain to frame clearance. Check that out first (and allow 3-4mm for sideways movement of the chain in each direction) before you go swapping arms.
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
  • Driv3r
11 Feb 2013 19:52
#571986
Thanks guys, just trying to find out which swingarem i can swap to have a fat tyre on my gpz900. I know zzr1100c is somehow compatible but I was trying to find another more recent model arm option that can take fatter than 180 and can be fitted by some machine work. Cheers
