KZ900 Spoke Wheel Options
- NakedFun
09 Feb 2013 00:44
Hi Ya'll....
So I sold off my stock KZ900 wires. I am starting to think I should have reconsidered that. I am thinking about buying a set and replacing them with 17" aluminum hoops. My question is, are there any disc wire wheel options around the 76-80 time period? I know they had them in 81+ , but they are awfully large hubs and if I sink the rim size down one size, you probable won't see a single spoke! Let me know what hubs were available.
Cory
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
1976 Kawasaki KZ900
- 4TheKZ1000
- wireman
Re: KZ900 Spoke Wheel Options
09 Feb 2013 00:53
76-78 900/1000 use same front wire wheel,so did 750 twins and early 650s.
As far as a disc brake rear wheel goes 77-78 kz1000 A-series would probably be easiest,750 twin also used disc brake rear wheel but Im not sure if bearing size is same
- NakedFun
09 Feb 2013 01:04
I have access to a '81 CSR front wheel which I think might be a decent match for the ZRX from forks and speedo drive. The rear I will keep an eye open for, but I am thinking about a a Kawi KLR650 rear hub. It is pretty streamline and may work well. Any one got a picture of the KZ rear hub or wheel with disc brake from the 78-80 like Wireman recommends?
Cory
Cory
1976 Kawasaki KZ900
1976 Kawasaki KZ900
09 Feb 2013 01:07
1977 KZ1000-A1 spoke with single disc
1978 KZ1000-A2 spoke with single disc and spoke with dual discs
09 Feb 2013 01:10
Lots of good info on kawasaki.com, including parts diagrams, part names, part numbers, models sharing same part, availability, etc. Here's a link for help with navigating the site and finding information.
kzrider.com/index.php?option=com_kunena&...w&catid=13&id=376734
- wireman
09 Feb 2013 01:24 - 09 Feb 2013 01:26
I used wheels/forks and swingarm off a 78 kz1000 on my z1
build first time around
Attachment z1-0668a15e9d2f4eac12f2d0e9ca39dbb9_2013-02-08.jpg not found
Last edit: 09 Feb 2013 01:26 by wireman.
- NakedFun
09 Feb 2013 16:46
Yep going to start with a set of hubs off a 81 CSR and adapt what I need to. Will have them re-laced with 17" hoops for my modern tires. Will post up pics when I start.
Cory
Cory
1976 Kawasaki KZ900
1976 Kawasaki KZ900
