Replacement brake lines
  • markc3wa
  • markc3wa's Avatar Topic Author
02 Feb 2013 12:37
#570380
I want to replace the brake lines on my 1978 KZ650D1. Any advice about what to replace them with? OEM/NOS parts are difficult to find and any used items would be suspect in my opinion.
Thanks!
Re: Replacement brake lines
02 Feb 2013 13:43
#570393
Z1 Enterprises lists a wide variety of brake hoses.
Click > www.z1enterprises.com/ListItems.aspx?keywords=brake+hoses
Good Fortune! :)
  • Kapahulu
  • Kapahulu's Avatar
05 Feb 2013 02:12 - 05 Feb 2013 02:12
#570834
The best place I've found to buy braided lines is Apex Brakes .
Take your measurements, call the guy up and he'll send you a great set of lines for cheap. For my KZ900 he did the front lines for about $50 including shipping. This is two lines, from the master to the junction and from the junction to the metal pipe that connects to the brake. The lines are covered with black plastic so they almost look stock.
Just make sure and get your fittings and measurements right or you'll have to order more lines.
2strokeworld.com
Last edit: 05 Feb 2013 02:12 by Kapahulu.
  • 78zed
  • 78zed's Avatar
05 Feb 2013 03:18
#570846
HEL make them to fit.
A bike on the road is worth two in the shed.
  • wireman
  • wireman's Avatar
05 Feb 2013 03:18
#570847
While youre at it it might be a good time to atleast replace seals in calipers and check pads
