Recommendations for a front master upgrade
- Granitestatekz
30 Jan 2013 13:55
Looking for my KZ1100 I rebuild the master last year but the bore is pitted and the front brakes will gett mushy or have to pump them a few times to feel firm. Looking for maybe an upgrade like a used unit from a new bike that is an easy bolt on . Plus I would also do steel braided lines too if I'm going that far.
- dejavoodo41
Re: Recommendations for a front master upgrade
30 Jan 2013 20:25 - 30 Jan 2013 20:26
I'm running a front master off of a CBR 600 F4i. It bolted right up and works great.
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
Last edit: 30 Jan 2013 20:26 by dejavoodo41.
- 893cv
31 Jan 2013 16:25 - 31 Jan 2013 16:26
I've used the master from a newer Ninja 650, it's very nice. It has an adjustable lever too. Look on Ebay, I think the one I used was only $35.00.
1980 kz1000 LTD
1978 Z1R
1978 Z1R
Last edit: 31 Jan 2013 16:26 by 893cv.
